I recently bought a rig off a guy and the hardware is far more powerful than what I'm used to. I'm experiencing some high cpu temps while gaming, in the range of low to mid 80s on Modern Warfare and high 80's in intense scenarios on Path of Exile. I'm running these games in 2k. The cpu usually idles at about 50C. Basically I need to know if it's safe to play at these temps for extended periods of time (6+ hours), what the maximum safe temp for my CPU is, if I need a different cooler/cooling setup, and what I should do about it if these temps are problematic. My idle room temp is about 70 if that matters for anything.
Here's the specs:
I9 10900kf
2080 ti asus rog strix
32GB(3600mhz) G.Skill Trident Z
1tb M.2 Intel 660p
750 gold plus EVGA
GA Be Quiet! Rock pro 4 cooler
My knowledge about PCs is very limited and I can't seem to find a definite answer anywhere, so please go easy on me. Thanks! :)
https://linustechtips.com/topic/1270490-safe-cpu-temps/
Here's the specs:
I9 10900kf
1tb M.2 Intel 660p
750 gold plus EVGA
Yes those temps are safe and pretty high for 10900kf without any overcloking. 10900kf uses a lot of power even at stock but DP4 shoudl cool it a little better. what is the pc case?
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14222319
As long as there isn't imminent damage from temps like that, I guess I'm not too concerned. What's a baseline temp I should be concerned about?
My case is: Rosewill ATX Mid Tower Gaming Computer PC Case Tempered Glass, CULLINAN V500 RGB
Thanks for the reply.
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14222326
Over 97C is when the damage can happen. Keep the cpu under 90c you will be fine.
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14222337
Case looks good but has bad airflow. but when temps are under 90C you will be fine
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14222343
Just now, Borckly said:
I see, thanks for the info. Appreciate the hasty and informative replies, saved me a lot of stress!
You all good. You have really good specs for 2k gaming. Enjoy :P
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14222353
Seems a little high. But 100C is max (and PC will shutdown at this temp) You may get lower performance atm, due to high temp and CPU throttling. I would reseat the cooler. First clean of CPU + cooler with isopropyl alcohol and then apply a big blob of thermal paste in the center of cpu, with a diameter the size of a chickpea, then the spread should be perfect.
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14222370
Alrighty I'll look into that. The guy I bought it off of didn't seem too bright so maybe he applied paste poorly on the cooler contact lol.
Thanks for the reply!
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14223453
I bought a Be Quiet! Dark Rock Pro 4 for my i9 10900k and had it installed but in about 2 minutes of use I ordered a 360mm AIO.
With the 360mm AIO the i9 idles at 30c and game at 60c. The reason for keeping it cool is TVB and that gets the CPU performing about the same as a 5.1 overclock.
To get better performance a 5.2 or 5.3ghz overclock is required and the i9 is very stable at high clocks so the only issue is thermal throttling. Not a problem in games but it is in some benches.
The i9 10900k only makes sense if it is running very cool or overclocked to 5.2ghz or more. Limiting it to the cooling capacity of a Dark Rock Pro 4 gets you neither.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14223783
Interesting, those are some drastic differences. Might consider AIO, I've always been spooked to try out water cooling though. Are there any air coolers you recommend over the Dark Rock Pro 4? Noise level isn't really a concern for me and I know that's what my current cooler prides itself on.
Thanks
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14223851
Thanks
This was the first time at water cooling for me.
My i7 8086k and i9 9900k use Noctua NH-D15s.
This was my second Dark Rock Pro and they are about 2c cooler than the Noctua. I don't know anything that is cooler.
The 360mm AIO was easier to install than the Dark Rock Pro but I had bought a case that was designed for water and that made it easier still.
https://linustechtips.com/topic/1270490-safe-cpu-temps/#findComment-14224309
