Update to a previous post:
Hi all. My wife and I are looking to upgrade our PC to get better performance out of our Adobe applications. Specifically we use Lightroom, Premiere, and Premiere Rush regularly. We are thinking desktop to save money but could be talked into a laptop. Does anyone have recommendations? Looking for the best value. I’m mostly working with 1080p/60 fps video.
Also, to be clear I'm unable to build my own system - I'd need something off the shelf.  Thank you!
Location is US and target budget is $1000
Edited by Barnabei
Forgot to indicate location and budget
budget and location?
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
