Building my First PC
Go to solution Solved by MarvintheParrot,
9 hours ago, Tylerwhisper said:
so the cheapest one out of the 3 what one would you say is best if i wanted to run 1440p
The cpu does not make the graphics better, it does a small amount when it comes to getting higher resolution. Your GPU current can run 1440p 60fps. I would go with the 3600 or the 3600x
Budget (including currency): 900-1000
Country: United States
Games, programs or workloads that it will be used for: Apex Legends, Destiny 2, Call of Duty, Battlefield, other modern games
Other details: I'm buying for Christmas but some parts early if they have black Friday or cyber Monday deals, I currently have most of my parts in a pc part picker list:https://pcpartpicker.com/user/Tylerwhisper/saved/#view=R7KTnQ: I was wondering if the Psu is good enough for small overclocking and if this pc would be able to run modern games well.
https://linustechtips.com/topic/1269966-building-my-first-pc/
Sorry, but I can't see that list, but here is one i made! :)
PCPartPicker Part List: https://pcpartpicker.com/list/ZD4z68
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  ($200.00)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard  ($114.99 @ Best Buy)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($86.99 @ Amazon)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive  ($59.99 @ Adorama)
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card  ($409.99 @ Newegg)
Case: Phanteks Eclipse P300A Mesh ATX Mid Tower Case  ($49.99 @ Newegg)
Power Supply: Cooler Master MWE Gold 650 W 80+ Gold Certified Fully Modular ATX Power Supply  ($105.98 @ Newegg)
Total: $1027.93
Generated by PCPartPicker 2020-11-16 19:04 EST-0500
its a bit over budget, but when more deals come out, it will be around $970
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14218453
Total: $1027.93
thank you for this^, I think I fixed the link does this one work:https://pcpartpicker.com/list/QGDL9N, i have already purchased the ssd and also the gpu is 409 on newegg
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14218469
Great build just a few things to add:
1: DO NOT BUY THERMAL PASTE THE CPU COMES WITH PRE-APPLIED THERMAL PASTE THAT IS MORE THAN ENOUGH!!!
2: If you feel comfortable overclocking, go with a 3600 or a 3600x as the 3600xt is just the same CPU with higher core clocks.
3: the Seasonic S12III is not the best unit. Above all other components, you should never cheap out on the PSU. The PSU basically holds the fate of your PC in its hands. Maybe if you save some money from a CPU down-grade+ no thermal paste, you might be able to fit in a better PSU, I recommend the Corsair CX (or CXM) 650W ($85)
4: The PC you have created will be able to run almost all AAA titles at at least 60FPS if not, higher. I really would go with a better PSU though, at least 600W+at least 80 bronze is my recommendation.
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14218482
tbh i don't really want to overclock too much (as i don't really understand it yet) so is the 3600xt still a good option or should i go with the 3600 or 3600x i was just a little bit confused, and also thank you for the advice about the thermal paste and psu
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14218492
I would go with the 3600x, if you don't want to OC.
There are 3 SKU's for the 3600:
3600
3600x
3600xt
the only difference is the base and boost clock. If you are doing gaming, pretty much any of them are good enough. Even a little streaming. You can go with any of them, but I would advise against going with the xt model, as there are many tutorials on how to OC, and its not all that hard.
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14218512
3600
3600x
3600xt
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14218838
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14219612
14 hours ago, jsugarman2005 said:
Have a look at this list...
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($199.99)
Motherboard: MSI B450M BAZOOKA MAX WIFI Micro ATX AM4 Motherboard ($93.98 @ Newegg) (It's a Micro ATX board but it does have onboard wifi and supports zen2 chips out of the box)
Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory ($53.79 @ Newegg)
Storage: Silicon Power A80 1 TB M.2-2280 NVME Solid State Drive ($114.99 @ Amazon)
Video Card: MSI Radeon RX 5700 XT 8 GB MECH OC Video Card ($349.99 @ Newegg) (You can squeeze in an rtx 3070 if you can find it for around MSRP, it would be a significant boost in performance)
Case: Cougar MG130-G MicroATX Mini Tower Case ($44.99 @ Newegg)
Power Supply: be quiet! Pure Power 11 600 W 80+ Gold Certified ATX Power Supply ($79.90 @ B&H)
Total: $937.63
Generated by PCPartPicker 2020-11-17 09:25 EST-0500
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14219902
Thank you very much for helping me with this
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14220021
Total: $937.63
They already have the GPU (rx5700xt for $409 on Newegg)
Also, I really don't think that that memory is a good idea, you can get much nicer and higher quality memory for around the same price.
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14220621
How does this look:https://pcpartpicker.com/list/DHvgBc I do already own the ssd in my old computer I am just gonna deactivate my windows key and wipe the drive and then transfer the ssd  and reactive windows but does everything in here seem to be ready to be bought. Once again thank you for helping me through this
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14220628
Looks great! The first upgrade that I would make is upgrading the PSU and the just adding a HDD or something, but the first upgrade should be PSU. :)
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14220675
Awesome, so the current psu, the corsair cx650m is good to start like I won't have any power issues but I will definitely check into  better one for my first upgrade should I look wattage or rating
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14220687
Oh! sorry, it still looks like you had the Seasonic S12III, the Corsair CX650m is enough for what you have +a few upgrades down the line such as a 3rd part CPU cooler. :)
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14220713
Nope that was my fault sorry for that here is the new list: https://pcpartpicker.com/user/Tylerwhisper/saved/rcG8rH
I also I'm not sure if it was different in the previous but I did change the motherboard  because the other one would didn't support the ram memory so I hope the one I have put in works.
Update: I decided to add the Crucial P1 1TB 3D NAND NVMe PCIe Internal SSD to the system
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14220755
Perfect!!
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14221800
The 5700xt that I have listed is $60 less than the one that you have listed. Also, OP can buy an rtx 3070, if he cn find it around msrp.
There is absolutely no problem with the memory. The DRAM chips that's used in that RAM comes from one of the three major producers. So, it's not that much of a difference according to me.
Also, the ram that you have listed is 3600mhz cl18 which is comparable to a 3200mhz cl16 kit. Having a 3600mhz ram isn't enough unless it has good timings.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14221993
Sure, I’ve just never heard of that memory before so I was just making sure. The OP has already bought the GPU.
https://linustechtips.com/topic/1269966-building-my-first-pc/#findComment-14222634
