CPU fan question
Go to solution Solved by LIGISTX,
They should be plugged into the same header to insure they will borth spin at the exact same RPM. What you can always do and I recommend, you can get a y fan slitter.
Something like these. Pretty cheap and handy to have.
http://www.amazon.com/s/ref=nb_sb_ss_c_0_6?url=search-alias%3Dcomputers&field-keywords=y%20fan%20splitter&sprefix=y+fan+%2Caps%2C291
https://linustechtips.com/topic/126982-cpu-fan-question/#findComment-1688858
My NH-D14 couldn't run on a splitter due to a lack of power.
I just connected each fan to a separate fan header and it turned out fine.
MY CURRENT PC
 CPU: Intel Core i7-4770k COOLER: Noctua NH-D14 MOBO: MSI Z87-GD65 Gaming ATX RAM: G.Skill Ripjaws 16GB DDR3-1600 STORAGE: Samsung 840 EVO 120GB SSD and Seagate Barracuda 1TB 7200RPM HHD GPU: Gigabyte G1 Gaming GTX 970 SLI CASE: Fractal Design R4 PSU: EVGA 1000W 80+ Gold
PERIPHERALS - KEYBOARD: Corsair Vengeance K70 w/ Cherry MX Browns MOUSE: Logitech G500/M100 MONITOR(S): Acer H236HLbid (I want an Asus PB278Q) SPEAKERS: Some Cyber Acoustics $10 speakers PICTURES AND FULL PARTS LIST @ PCPARTPICKER - http://pcpartpicker.com/b/z4Pscf
"Don't get so caught up in trying to make a living that you forget to make a life."
https://linustechtips.com/topic/126982-cpu-fan-question/#findComment-1688881
