Advice
Go to solution Solved by Speedbird,
4 minutes ago, Stygian Zenith said:
@Speedbird if its too weak i think i should get a ryzen 9 5900x and a 3090 if its available
Your six core CPU will run it just fine, even when playing. I've done it on a 4 core APU with 8GB RAM.
LTT's unofficial Windows activation expert.
https://linustechtips.com/topic/1269721-advice/#findComment-14216386
Just now, Stygian Zenith said:
@Speedbird Ok thanks! I seriously thought I needed high end gear like what linus used for his minecraft server!
I believe he's running mods, which consume a lot more resources (especially RAM). Vanilla can run on a potato.
https://linustechtips.com/topic/1269721-advice/#findComment-14216398
