UPS basics
Solved by Beef Boss,
18 hours ago, Electronics Wizardy said:why not ask you teacher? were aren't here to do your homework.
Normally with that size of a ups, your using 208/240v and hardwiring it in.
I have researched the type and seen all posted images of the UPS, I just wanted to know if there is an additional component for these rack mount units to have an output usable for 120vac devices. The images I found did not have this rather a bunch of 250volt outputs which are useless for a 48 port switch. Other UPS's have an additional component/unit that stacks on top giving the output receptacles I'm looking for.
I switches from one main UPS to four separate units. Thanks.
