My brother is opening a tattoo shop and asked if I could build him a setup for the front desk. Mainly for spreadsheets, managing applications, timesheets etc. for his business. He doesn't want anything flashy or top tier, he just wants something simple and functional.
Can you guys give me some input on this list?:
http://pcpartpicker.com/user/guziiii/saved/42y7
EDIT: his budget is strictly 400 (after taxes & shipping), give or take a few bucks
Rig
CPU: 4770k @ 4.2GHz 1.15v | Mobo: ASUS z87 Sabertooth | Cooler: Corsair H110 | RAM: Vengeance 32GB DDR3 @ 1600MHz | GPU: GIGABYTE G1 GTX 1070 | Storage: Samsung 840 series 250GB SSD, Seagate 2TB SSHD, Seagate 4.25TB HDD | PSU: Corsair AX850 80+ gold modu | Case: Corsair 650d | Keyboard: Corsair K65 RGB Cherry MX Reds & a Leopold 210TP Numberpad Cherry MX Blues | Mouse: Logitech G502, DECHANIC desk mat | Monitor: 2x Dell IPS 23" S2340m & ASUS 144hz 24" VG248QE | Speakers: CA-3602a | Headset: Steelseries Syberia v2 Frost Blue OS: Win 10 Pro
https://linustechtips.com/topic/126942-small-business-rig/
Psu is overkill. Get a lower end apu or go to an intle pentium or i3. Get 8gb ram, it really helps.
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1688374
i highly recommend the intel g3220, really lower power usage and its pretty damn fast for what it costs, i run one in my home server that boots off an old 64gb ssd and it boots as fast my gaming rigs, its really smooth opening programs, i also have one in my work pc and it handles plenty of multitasking (i do lots of excel at work and lots of internet tabs)
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1688404
That power supply is a bit overkill.
its $20
Rig
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1688420
An I3 (doesn't really matter which one 2 gen and up) or FX-4300 would probably be a better choice as this rig needs to endure years without upgrades.
the cheapest i3 chip is over $100, and paired with an intel chipset would be well over his budget. sticking to amd apu's since a dedicated gpu wouldn't be price efficient also
Rig
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1688445
this might actually work. i plugged in the g3220 with the cheapest/decent motherboard (msi h81m-p33) and it's just a few bucks more than the 5400k build. Do you think it would be a better build with the g3220 over the 5400k?
Rig
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1688485
Fair enough.
Mein Führer... I CAN WALK !!
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1688491
g3220 is half the power consumption (40w vs 80w) so half the cost to run and has much better single threaded performance, which for basic programs should be quicker, should also run cooler and require less noisy fans
unless he needs multithreaded support but not sure if programs like excel and word and programs of that ilk take advantage of it
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1688499
CPU wise it's a bit more powerful and he really doesn't need that powerful of graphics so I'd say go for it.
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1688500
PCPartPicker part list / Price breakdown by merchant / Benchmarks
CPU:  Intel Pentium G3420 3.2GHz Dual-Core Processor  ($69.99 @ Amazon)
Motherboard:  ASRock H81M-HDS Micro ATX LGA1150 Motherboard  ($49.99 @ Microcenter)
Memory:  Crucial Ballistix Sport 4GB (2 x 2GB) DDR3-1600 Memory  ($47.47 @ NCIX US)
Storage:  PNY XLR8 120GB 2.5" Solid State Disk  ($64.99 @ TigerDirect)
Case:  Xion XON-720P_RD MicroATX Slim Case w/300W Power Supply  ($34.99 @ Newegg)
Optical Drive:  LG GH24NSB0 DVD/CD Writer  ($15.99 @ TigerDirect)
Monitor:  Hannspree HL205ABB 60Hz 19.5" Monitor  ($79.99 @ TigerDirect)
Keyboard:  HP Wireless Classic Desktop Wireless Standard Keyboard w/Laser Mouse  ($17.99 @ Amazon)
Other: 2.5" HDD/SSD Metal Mounting Kit  ($5.00)
Total: $386.40
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-03-13 23:02 EDT-0400)
https://linustechtips.com/topic/126942-small-business-rig/#findComment-1690934
