Hey guys,
I've got a little problem, I'll try to explain it thoroughly.
Last weekend I provided my rig with some custom watercooling parts, but upon restarting it looking at temps something strange happened.
I started Metro/Tomb Raider for some temp/fps readings and here is the problem.
Crossfire enabled with 14.2 beta drivers (clean install)
=> temp gpu1 went from 29°C to 100/104°C with 100% load ingame, fps was around 15fps
=> settings where high on 1440p (On air I got high fps)
=> lowered to 1080p, same amount of fps between 15-20fps
=> Same problem with Metro and Battlefield 4 (though Battlefield 4 ran a bit better)
I did have a crash 10 minutes in game.
Next test I did, was with gpu 1, crossfire disabled, same temp spike and even lower fps.
Tried out gpu2 seperatly and it works but same low fps and high temp.
=> Clean windows 8.1 install, clean 14.2 beta instal
Ran Furmark and temps would go to 104°C but would come back down to 52°C and remained there. GPU 2 didn't do anything 0% even though Crossfire was enabled.
Same low fps problem ingame though.
=> removed 14.2 beta drivers and installed 13.12 drivers.
Temps back to 100/104°C and same extreme low fps, crash after around 10minutes.
Upon feeling the waterblock they are not warm,
I checked bios, pci 3.0 enabled and both cards stand at 8x
I got recommanded to drain my loop and reseat the gpu blocks, but first test them on air.
Has anyone here got another solution before I do this?
Specs:
2x HD7870's from Sapphire
i5 3570k
Corsair AW750
Asus Sabertooth z77
Asus essence stx soundcard
1x 360 rad
1x 200 rad
D5 pump
EK waterblock for gpu and cpu
Nothing overclocked!
https://linustechtips.com/topic/126866-gpu-trouble-after-first-wc-loop-help/
104 c on a gpu? Holy...
Well I think it's pretty obvious that your water blocks are not making good contact with the gpu...
Are you sure the pump is working etc?
CPU: Intel i7 3970X @ 4.7 GHz  (custom loop)   RAM: Kingston 1866 MHz 32GB DDR3   GPU(s): 2x Gigabyte R9 290OC (custom loop)   Motherboard: Asus P9X79
Case: Fractal Design R3    Cooling loop:  360 mm + 480 mm + 1080 mm,  tripple 5D Vario pump   Storage: 500 GB + 240 GB + 120 GB SSD,  Seagate 4 TB HDD
PSU: Corsair AX860i   Display(s): Asus PB278Q,  Asus VE247H   Input: QPad 5K,  Logitech G710+    Sound: uDAC3 + Philips Fidelio x2
HWBot: http://hwbot.org/user/tame/
Yup pump is working, can see it in reservoir.
cpu temps are normal around 20-25°C depends on the core.
I guess there is no other solution than draining and reseating the loop.
Sorry if I misplaced the topic  :blush:
Were the GPU on a bridge that is set up parallel? Usually parallel set up might be a nightmare if air bubbles are stuck between or in. Or maybe you should go into bleed mode, only running the pump for 72 hours and also turning the speed of the pump up and down a couple of times if you have the dial.
That should ensure no bubbles were stuck and might narrow down your problem. Good luck!
got a picture of your loop?
prolly a large air pocket stuck in the GPU causing high temps, fixed a couple
already with massive air trapped in the GPU. tip and tilt case (system off)
to work out any air pockets left in the system.
holy moly this would scare me so much... 104C on a GPU is enough to kill it instantly
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
It's working again! I took the gpu's out and reseated the blocks, I didn't use enough termal paste and might not have tightened the screws enough.
Everything is working smoothly again. Idle temps are now 24°c, haven't really tested it, but 5 minutes of furmark on 1440p gave me 32°C and 68 fps (that's good right?)
I'll do some more testing tonight, it was late yesterday.
Here's some pics, the drive cage on the outside was temporary.
Looking good :)
Well, atleast you haven't fried some eggs... I like the paste on them thermal pads  :rolleyes:
Oh btw, where will you place the HDD / SSD tray later?
|EVGA 850 P2| |1440p PG279Q| |X570 Aorus Extreme| |Ryzen 9 3950x WC| |FE 2080Ti WC|TridentZ Neo 64GB| |Samsung 970 EVO M.2 1TB x3
 |Logitech G900|K70 Cherry MX Speed|  |Logitech Z906 |  |HD650|  |CaseLabs SMA8 (one of the last ones made)
Very nice save, or else it could have been a wallet battering moment to say the least.
Core - EVGA Classified 3 | i7 980x | 12GB Corsair Dominator GT | Lian Li P80 | Corsair 128 Neutron GTX | 2 x WD 500gb Velociraptor | Asus Xonar Xense | 2 x EVGA 590 | Enermax Platimax 1500
Water Cooling - Alphacool NexXxos 360 Monsta | TFC 360 | Alphacool D5 Vario | Alphacool 250 Tube res | EK Supreme HF Nickle Plexi | 2 x EK Nickle Plexi 590 WB | Aquaero 5 XT
