Ram Help for my First Build
Solved by Deslumo,
The Vengeance Pro RGB sticks have tall heatspreaders, so if you're going with an air cooler, be aware of that. Regarding memory, both are fine, you could either try and OC to 3600MHz, or try and tighten up the timings to get the CL16.
Featured Topics
Hamborgor ·
Posted in New Builds and Planning1 -
Sai125943 ·
Posted in Graphics Cards2 -
zombiepunk10 ·
Posted in General Discussion3 -
Mechernsee ·
Posted in Graphics Cards11 -
8
FoxYolk ·
Posted in Graphics Cards8 -
11
Ridethehorse ·
Posted in Troubleshooting9 -
3
