hey guys sort of a weird ask but does anybody know if its possible to get 2* C battery pack that's rechargeable? it needs to be one on top of the other, not side by side..
anything is appreciated
The Beast [Case -  Corsair 750D CPU - I5 4670k @ 4.3ghz 1.2V CPU cooler - Hyper 212 evo Mobo - MSI g45 z87 RAM - G.Skill Z series 4*4@1866mhz GPU - Gigabyte windforce 3x r9 290 Storage - SSD, samsung 840 evo 120gb HDD, Western Digital Blue 1tb PSU - SilverStone Strider silver 80+ 750WPeripherals [Monitor - ASUS VS239 IPS 23" Keyboard - Corsair K95 Mouse - Mad Catz RAT 7]
https://linustechtips.com/topic/126829-battery-packs-rechargeable/
maybe this??
http://www.onlybatterypacks.com/showitem.asp?ItemID=11512.33
What are specifications do you need for the battery pack exactly?
needs to be on on top of the other, using it for a rc car - weird old thing
What are the voltage, capacity and Amps needed for the battery for the RC car?
same voltage as all C batteries but, as long as its cylinderal and the same diameter. also, the higher amps the better - lasts longer
I'm confused. How many do you need? What RC car is it?
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
I would suggest to refer to the old battery and get one of the same specifications and type to make sure everything is compatible, not sure if batteries can just be switched like that since I don't really know much about RC devices.
But as in stacked you meant something like this correct?
They have dimensions of 2 C cell batteries using Sanyo N3000CR Cells
Sanyo N3000CR Cell Specs:
http://media.digikey.com/pdf/Data%20Sheets/Sanyo%20Energy/N-3000CR.pdf
if someone has a better idea on RC devices please weight in  :D
