Hello all, I set up a Minecraft server on my HP-Proliant Dl360 G6 and it is working Fine on LAN, but I cant access it out of network, I already went into my router and forewarded 25565 to my server and tried using my public IP address but got a timed out error, any help is appriiciated and more info can be provided.
https://linustechtips.com/topic/1268143-help-with-portforwarding-minecraft-server/
theres usually a video on how to port forward with your router on youtube etc. but without your router model we cant help
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://www.linksys.com/us/support-article?articleNum=138535 heres a guide
not a good idea to host on your home network, youre leaking your ip address to everyone around, if youre going to host on your home network use a vpn, you could get a vpn that you open ports with and skip this step entirely
AMD blackout rig
Just now, Letgomyleghoe said:
I already went through this guide, I have a port forward setup, the issue is when I try to connect it says connection refused.
https://www.canyouseeme.org/ try and verify the port is actually open
AMD blackout rig
I got this:
Error: I could not see your service on XX.XX.XXX.XX on port (25565)
Reason: Connection timed out
2 minutes ago, AndrewMKlasen said:
I got this:
Error: I could not see your service on redacted on port (25565)
the ports still closed, and you just leaked your ip...
AMD blackout rig
3 minutes ago, AndrewMKlasen said:
Any suggestion on why it's still closed? and I redcated it
your isp might block it from being opened, what isp do you use?
AMD blackout rig
AMD blackout rig
I totally agree with that, you should definitely do that if you are opening ports.
1 hour ago, Donut417 said:
So I’ll take it you own your own modem or are you using what Xfinty provides?
Yes I am using a modem that Xfinity provides, I do plan on buying my own soon.
This is a whitelist server for me and a couple friends to play on so I won’t be rly leaking it out unless I un-whitelist the server
That’s your problem then. Xfinity doesn’t provide modems. They provide gateways. A gateway is a modem and router in one. So if that gateway is not in bridge mode, it’s also acting as a router. Which explains why your having issues.
3 hours ago, Dango said:
Can you post your port forwarding config? (Make sure to cover your wan IP)
It sound like miss configuration on the network side.
No the issue is the OP is double NATed. Comcast only issues internet gateways (Modem/Router) and the OP is using a 3rd party router. So while the OP is port forwarded, the OP still has a second layer of NAT to worry about due to the Comcast gateway. When the OP buys a standard cable modem, the issue should be resolved.
