1 minute ago, Henrymardh said:
ive been having trouble with xmp with my asrock b450a/c motherboard i tried to set my ram to its advertised speed (3200 mhz) and it stays at 2133 please help its my birthday and i just built the pc
What's your ram? Tell me the model and the speed.
Try using this guide:
https://www.tomshardware.com/reviews/how-to-enable-xmp-ddr4-overclocking,6133.html#:~:text=Motherboards and processors that don,it's automated via Intel XMP.&text=XMP typically means running the,2666%2F2400 MHz...
If it doesn't work, you're gonna need to do it manually by inputting the profile given with the ram manually into the speed, voltage and CL.
8 minutes ago, Henrymardh said:
Ryzen 5 1600
1st gen Ryzen is much more finnicky than newer Ryzen in terms of RAM, and for your specific motherboard anything above 2666Mhz is classed as OC (for 1st gen Ryzen) so Asrock can't guarantee it will run at those RAM speeds. Scroll to "Memory" section, refer Summit Ridge
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
