the bios to support the 3200g was released in may 2019 for that board. so unless you're unlucky to receive really really old stock, it should come with the right bios.
i would however say that if you ever plan to upgrade this pc to give it more performance, it would be better to invest in a better motherboard now, a b450 pro-4 or pro-vdh
https://linustechtips.com/topic/1267800-pc-build-help/#findComment-14200354
I see I see, I'll keep that in mind. Thank you very much.
https://linustechtips.com/topic/1267800-pc-build-help/#findComment-14200357
