Overclocking CPU questions
Solved by Dave :),
Personally, i wouldn't risk it. Mainly as that PSU is fairly low powered, and with it being OEM, i wouldn't trust it to offer the required power all the time. That said, you may be able to overclock without having to touch the voltages, so it's always worth a shot - if you do, make sure you stress the CPU adequately.
Above all else, and this is a big thing, make sure you have access to the BIOS features which you need to overclock (CPU Freq, CPU Multiplier, Voltages etc). Many OEMs such as HP, Dell etc lock their BIOS so you can't have access to these options - mainly to prevent damage to the computer. I would first get into the BIOS and check to see if these options are available to you.
