Budget (including currency): $150 (Australian Dollars)
Country: Australia
Retailers I'll be shopping at: https://www.ple.com.au/ https://www.austin.net.au/https://www.amazon.com.au/
(NOTE: These shops are also on pcpartpicker so you will be able to use this to make choosing parts easier)
What for?
Hello there, I was wondering on what i should do to make my pc look aesthetically pleasing. I'm kinda on a budget and i was hoping to get some advice. Lately, I have been seeing some really aesthetically pleasing pc builds and like the way aio's looks, so if possible an AIO would be able to be in the budget. (My cpu and mobo are the ryzen 5 2600, asus prime 450-a if that matters)
What My PC Looks Like Right Now:
Btw sorry for the bad image quality, didn't feel like opening the glass. Takes to much time.
https://linustechtips.com/topic/1267362-help/
The only correct answer here is adding another $150 worth of Looney Tunes merchandise
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
https://linustechtips.com/topic/1267362-help/#findComment-14196755
@AereldorLMAO, the only reason why i have so many looney toons figurines is because mcdonalds happy meal with a coke, fries and a burger costs the same of a single burger. Right now they are doing looney toons so i have so many now... But anyways please give advice, serious ones..
https://linustechtips.com/topic/1267362-help/#findComment-14196770
I'm serious, Looney tunes fuckin slaps. And a PC with stuff inside it is more interesting with boring harsh RGB lights that showcase dull ass circuit boards and plastic flanges.
Maybe put in some soft light to exhibit the figurines better. A good way to do that is to get an LED strip and hide it behind something so the bulbs aren't directly visible.
https://linustechtips.com/topic/1267362-help/#findComment-14196857
1 hour ago, Stygian Zenith said:
@AereldorThanks! I think i should just follow your advice by adding some strips and add an aio cause i like the look. I might even try getting a custom gpu backplate for my rtx 2060 super that is looney tune theme.
Careful, most AIOs are outperformed by cheaper air coolers. Custom backplate is tacky IMO, but the figurines are sick. For the strips I'd go with soft white/yellowish LEDs, somewhere between 2800k and 3500k in colour temperature. To avoid making it look too modern, fitting in with the theme.
https://linustechtips.com/topic/1267362-help/#findComment-14197306
@Aereldor Could you please link some specific strips? Kinda new to these rgb things, as you can see from my pc...
For the aio, i was thinking of making it like a yellow/red rgb colour (rgb fans on aio). Ik some may get outperformed but.. aesthetics.
https://linustechtips.com/topic/1267362-help/#findComment-14197331
Didn't mean RGB strips, I meant regular ass LED strips.
These are incredible, but they're a tad expensive.
https://www.amazon.com.au/Marswell-Photographers-Christmas-White-Non-Waterproof/dp/B06XQLJM9P/
These are okay, and cheaper, but they take a while to ship
https://www.ebay.com/itm/282145478766
https://linustechtips.com/topic/1267362-help/#findComment-14198072
