Finally done, had to compromise on a few parts due to availability, but easily upgradable once more stock is available. Although I am more than happy with this setup. I wanted either a 5900x or 5950x, but they had limited stock and had to settle for 5800x, did not want to wait, same goes for GPU, all that was available is a RTX2060 so I figured a RX5700 XT would do me just fine for now and it does. Will wait for the new 6000 series GPU from AMD, but as of now this setup is running everything quite well. Im still deciding on a good monitor, right now im just running some HP 24es 60hz cheapness I had laying around, so if anyone has a good suggestion for a decent monitor I'm all ears
  • Case: Lian Li O11D XL
  • Motherboard: Gigabyte X570 Master
  • CPU: AMD Ryzen 7 5800x
  • GPU: ASUS Radeon RX5700 XT Strix O8G
  • Cooler: ASUS ROG STRIX LC 360 RGB AIO
  • RAM: G.Skill Trident Z NEO Series 32GB DDR4 3600MHz CL16 Dual Channel Kit (2x 16GB)
  • SSD1: Samsung 970 Evo Plus 1TB
  • HDD1: Segate 8TB BarraCuda HDD, SATA III w/ 256MB Cache
  • PSU: Corsair RMx Series RM850x 80+ Gold Fully Modular ATX Power Supply, 850W
https://linustechtips.com/topic/1266816-finally-build-done/
damn nice buld, interesting choice on the aio and fans
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1266816-finally-build-done/#findComment-14192014
Thanks. Just what was available for fans at the time and I wanted this up and running, I want to get my hands on the Lian Li UNI Fans, and eventually do a custom water loop with EK blocks, that was the one reason I went with x570 master and the RX5700 XT Strix as EK has water blocks for these parts.
https://linustechtips.com/topic/1266816-finally-build-done/#findComment-14192045
