Budget (including currency): low 2000s
Country: US
Games, programs or workloads that it will be used for: Mainly Gaming, 70% gaming 30% productivity
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc):
I hope you are having an amazing week! I was wondering if someone could help me with my PC design. I am mainly going to use it for gaming, with some video editing and 3d design. I have my build pretty much designed, but I am having some second thoughts on some of the parts. First for my build, would it be worth going for the Rysen 7 5800x vs my i9 9th generation cpu? On the topic of Cpu's should I go with water-cooling for air cooling for the build. I heard that water cooling can leak, or break, but i also heard that it cools better. Depending if I get the Rysen or the Intel CPU, what cooler should I choose?
The next part is my motherboard. I am planning on the MSI Z390-A PRO ATX LGA1151 Motherboard. If I was going to go with Rysen, what motherboard would you suggest? The same with intel. If the board if not Wifi, what wifi adapter would you suggest. My wifi can go up to speeds of 300-400 Mbps, so maybe wifi 6?
My build is above, and if you have any other suggestions for my build, I would gladly take them. The budget is around the low 2000s. Are there any adapters that I need? Extension cords? If there is a better product that is cheaper, or near the same price, let me know!
(Something slightly unrelated. Where can I get cheap windows keys)
MY BUILD IS HERE: https://pcpartpicker.com/list/byrcTJ
https://linustechtips.com/topic/1266803-some-build-questions/
Definitely go with the new ryzen. Even the 6 core 5600x beats the 9900k in all scenarios. A good b550 board like asus tuf wifi or msi tomahawk wifi should do the trick.
A good air cooler is enough, ryzen doesn't use that much power. A dark rock 4 or a nh-d14 should be plenty.
Get a different case, preferably with a mesh front. The h510 is a hot box with poor airflow.
https://linustechtips.com/topic/1266803-some-build-questions/#findComment-14191925
Hmm. Ok. Would you suggest the asus tuf wifi or the msi tomahawk wifi? Do both of them support ethernet? Also, what case would you suggest them?
https://linustechtips.com/topic/1266803-some-build-questions/#findComment-14192387
Yes they all support ethernet
PCPartPicker Part List
Type Item Price
CPU AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor $300.00
CPU Cooler Cooler Master Hyper 212 RGB Black Edition 57.3 CFM CPU Cooler $34.00 @ B&H
Motherboard Gigabyte B550 AORUS PRO AC ATX AM4 Motherboard $174.99 @ Amazon
Memory Crucial Ballistix Elite 32 GB (4 x 8 GB) DDR4-3600 CL16 Memory $159.99 @ Newegg
Storage Samsung 970 Evo 500 GB M.2-2280 NVME Solid State Drive $69.00 @ Amazon
Storage Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive $54.99 @ Newegg
Video Card Asus GeForce RTX 3070 8 GB STRIX GAMING Video Card
Case Phanteks Eclipse P400A Digital ATX Mid Tower Case $94.98 @ Newegg
Power Supply Antec High Current Gamer Gold 750 W 80+ Gold Certified Fully Modular ATX Power Supply $120.98 @ Newegg
Case Fan ARCTIC F12 CO 74 CFM 120 mm Fan $12.35 @ Amazon
Monitor LG 27GL650F-B 27.0" 1920x1080 144 Hz Monitor $299.80 @ Amazon
Mouse Glorious PC Gaming Race MODEL O Wired Optical Mouse
Headphones SteelSeries ARCTIS 7 2019 Edition 7.1 Channel Headset $125.00 @ Walmart
Webcam Razer Kiyo Webcam $109.94 @ Office Depot
Custom CORSAIR K70 RGB MK.2 RAPIDFIRE Low Profile - Backlit RGB LED - USB Passthrough & Media Controls - Fastest & Linear Low Profile - Cherry MX Speed $119.13 @ Amazon
Custom Large RGB Gaming Mouse Pad - Soft Non-Slip Rubber Base Led Mousepad, Thick Computer Keyboard Mice Mat for MacBook, PC, Laptop, Desk(31.5 x 11.8 x 0.15In) $18.98 @ Amazon
  Prices include shipping, taxes, rebates, and discounts
  Total (before mail-in rebates) $1704.13
  Mail-in rebates -$10.00
  Total $1694.13
  Generated by PCPartPicker 2020-11-09 01:35 EST-0500
https://linustechtips.com/topic/1266803-some-build-questions/#findComment-14192658
