Is there an external front panel module anywhere?
I may be testing out a really old motherboard at school and need to know if there is a small handheld module that had power/reset buttons on it because this board does NOT have an onboard power button. (The cpu is an i386 DX clocked at an ultra fast 23/33MHz...)
So basically I am talking about a small handheld device that has a power and reset button on it. This would be connected to the front panel header on the board, which will be sitting on a ghetto test bench, and ran from there.
If you do find one let me know!
Of course I could just DIY it and yank a front panel module from a case and run it like that...
https://linustechtips.com/topic/126676-external-front-panel-module/
just find out what pins the power and reset buttons will be plugged into and just bridge the two pins together with a paper clip.
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
How does that stop your from shorting a reset or power on?
Because I have to constantly do it since DOS can't do a software shutdown and it gets annoying. Eventually I will end up forgetting which is which.
Oh and there is some disgusting brownish crusted stuff on the bottom of the board, how should I go about removing it?
I would just use a razor blade or key to bridge. Not worth rigging a switch up for a bit of mucking around.
i5-3570k @ 4.4ghz (1.240v) || Asrock extreme 4 || CM Hyper 212 evo
Samsung 840 || WD blue 1tb || WD green 1tb || Powercolor 7870 xt @ (1200 mhz core : 1500 mhz mem)
Powered by a silverstone strider 500w psu in a NZXT 210.
It might become a semi-permanant test bench!
Still need an AT PSU and an ISA graphics card...
The PSU I can probably yank from the teacher's rig, the ISA gpu i will need to find someplace...
Well fair enough if you are going to set a bench up that will see a bit of use, first impression I got was a once or twice use job.
I always use a screwdriver tip...
Just jam it down in that area and wiggle til you see lights come on, haven't blown up a motherboard yet.  B)
EDIT: Forgot to refresh the page to check for new comments... had it open for quite a while.
Do you have a bunch of old case parts by chance? If so, take a picture and I bet I can find some things in there you can cobble together that would work for this.
Or be lucky like myself and jag a modsmart vandal switch for $9 AUD :) when I saw one in the colour I wanted at that price I couldn't say no.
