Had this problem for a while now where I will be playing a game and will get this weird audio stutter which follows by fps drop. It happens like every hour or so and sometimes I can even hear like USB connections disconnecting and reconnecting if that has anything to do with it I'm not sure. Could it be a Power Supply issue because I noticed to usage drop on my CPU, RAM or GPU when in use.
For extra info here are my pc specs:
-Ryzen 5 3600
-32gb Corsair Vengeance 3200mhz
-650w Corsair PSU
-RTX 2070 Super 8gb
-Samsung evo 500gb and 1tb ssd
-I also run 3 monitors 2 144hz and 1 240hz
https://linustechtips.com/topic/1266665-fps-and-audio-stutter/
I would check to make sure that all your drivers for your motherboard are up to date, if that doesn't work you may want to update your bios to a newer version
Optical Drive Poll: https://linustechtips.com/main/topic/1006309-optical-drive-survey/
Main Rig (Redshift)
CPU: Ryzen 7 9800X3DX MOBO: MSI MAG X870E Tomahawk WIFI RAM: G.Skill Flare X5 (2x16gb) 6000MT/s 28-36-36-96 GPU: Sapphire NITRO+ 9070XT, Cooler: Noctua NH-D15 Chromax Storage:  Intel S3520 150gb x4 RAID0 for boot, Crucial P310 4tb x2 RAID0, MSI Spatium M470 1tb, SK Hynix Platinum P41 2tb,  Case: Phanteks Evolv X2 PSU: Seasonic Foucs GX 850W OS: Windows 11 Pro 64 bit
HexOS Server (Vault)
CPU: Xeon E5-2603v3 MOBO: MSI X99 Tomahawk RAM: G.Skill Aegis (4x8gb) 3000MT/s 16-18-18-38 GPU: Headless Cooler: Cooler Master Hyper 212 LED Storage: Intel S3520 150gb x2 for boot RAID1, x16 in RAIDZ1 for storage, LSI 9305-16i HBA,  Case: Phanteks Enthoo Pro Tempered Glass PSU: EVGA SupeNOVA G1+ 750W
https://linustechtips.com/topic/1266665-fps-and-audio-stutter/#findComment-14191094
Followed and done this still having the issue :(
https://linustechtips.com/topic/1266665-fps-and-audio-stutter/#findComment-14202118
