Hi all I just got the 3070 founders edition and I’m wondering if I can use my extension cable with the adapter? So can I use the extension and attach it to the 12 pin adapter or should I take the cable out and use my PSU original pcie cable to connect to the adapter?
https://linustechtips.com/topic/1266349-extension-cable-with-3070-fe/
the extension should work fine.
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
