On every single video I watch weather it is vevo video or just any video. My screen freezes for a second when watching a video or playing games but in general it freezes up even when typing the screen will freeze for a second. I think this is due to the new graphics update 14.2 on amd 7970 ghz. Before I was on 1160 mhz core stable but after the update it was no longer stable and I had to revert back to the 1100 mhz default I did the same with the oced memory clock of 1600 mhz which had to be clocked back down to 1500 mhz. Is this a graphics card problem, graphics software problem?
[CPU] i7 4790K OC [CPU Cooler] H100i [GPU] Evga GTX 980 SuperClocked [Ram] Corsair Vengeance 16 GB 1866 mhz [PSU] Cooler Master 1000w Silent Pro [storage] 256 GB Samsung 840 Pro, 1TB Seagate SSHD, 1 TB WD Blue 4 TB Seagate Nas. [Motherboard] Msi Z97 Gaming 5 [Case] Phantom 410 Red [sound] Onboard ALC 1150 [Headphones] Sennheiser HD 558 [Keyboard] Razer BlackWidow Chroma  [Mouse] Razer Deathadder Chroma [Mouse] Razer FireFly [Monitor] Asus MG278Q
https://linustechtips.com/topic/126628-problems-with-stuttering/
Check the refresh rate of your monitor. I had this problem and even though it is suppose to be 60hz I had to set my computer to 59hz for it to be smooth, no idea why.
My Rig :  Case: Cooler Master HAF X ,Motherboard: Gigabyte Z87X-UD3H,PSU: Seasonic SS-750KM3,Processor: Core I7 4770k (overclocked 4.7ghz),Cooler: Corsair H100i, GPU: EVGA GTX 780 with acx cooler, RAM: G.Skill Ripjaws 16gb DDR3 1600 (overclocked to 2000mhz), HDDS  Samsung 840 EVO 250 gb SSD , Western digital  2tb 7200 rpm 64mb cache, Old 1tb laptop drive I had , 320gb for os backup daily, 80gb external for weekly backups,Drives 2x Lg Blu Ray burner WH16MS40,MISC: Tp-Link dual band wireless card, Logitech g510s, Razer Deathadder 2013, Acer G236HLBbd 23" monitor, Old tv I had 23" for secondary monitor, old 32" samsung tv third monitor
https://linustechtips.com/topic/126628-problems-with-stuttering/#findComment-1684259
Unfortunately that was not the case. @scaryjam823
https://linustechtips.com/topic/126628-problems-with-stuttering/#findComment-1684517
Roll back to 14.1 or use the stable drivers, i remember reading somewhere that 14.2 was giving problems to some cards
Main rig. Updated :D CPU: FX8350 @stock Cooler: Corsair h110 Motherboard: Ga-990fxa-ud5 Memory: Corsair Vengance 8Gigs 1866Mhz GPU: MSI GTX 970 SLI (blower cooler)  PSU: Cooler Master Silent pro 850w SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue Case: Thermaltake core V71 Fan controler: NZXT Sentry
Secondary PC: CPU: i5 4670k @stock Cooler: Thermaltake NIC L/31 Motherboard: Asus Z97I-PLUS Memory: Corsair Vengance 8Gigs 2133Mhz GPU: ZOTAC GTX 780 (Titan cooler) PSU: Antec 520m Pro SSD: Corsair Force GT 60Gb HDD: WD 500 Caviar blue & WD 2TB Green Case: Thermaltake core V1
https://linustechtips.com/topic/126628-problems-with-stuttering/#findComment-1685564
I think your right I have been getting errors with OC also and my core clock won't stay 1100 mhz. But question When uninstalling the Graphics card drivers which ones do you uninstall in the custom uninstall? I am using a AMD cpu gpu and the system drivers and graphics are linked. (I def do not want to uninstall any system drivers) @SkulD
https://linustechtips.com/topic/126628-problems-with-stuttering/#findComment-1685717
I would just un-install everything with using the standard Catalyst uninstaller, since you'll be re installing everything again.
You can always choose custom uninstall and select only the graphics and hdmi drivers.
I strongly advice that you do NOT install the hdmi sound driver, because i have seen that it causes cobflicts with the onboard audio which causes pergormance problems as well as video driver crashes.
Im terribly sorry for the late reply, buy have been very busy with work lately.
https://linustechtips.com/topic/126628-problems-with-stuttering/#findComment-1693938
