Yes you can run memory at lower speeds.
iirc you can set xmp and higher speeds on that chipset though
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
https://linustechtips.com/topic/1266278-memory-speed-problem/#findComment-14188117
H110 was pretty limiting on ram speeds, outside of Z170 there were pretty few motherboards that allowed for XMP profiles past 2400.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1266278-memory-speed-problem/#findComment-14188143
2 minutes ago, Stillchained said:
But is it possible to do this with this combo?
If your motherboard has a 2400 profile it can probably do it
Primary PC:
PSU tier list
https://linustechtips.com/topic/1266278-memory-speed-problem/#findComment-14188195
