Need help formating my boot drive
On 11/6/2020 at 10:05 PM, -WHIZ- said:
I am transferring my SSD which has Windows 10 OS on it and im trying to format but the format option is greyed out
Just so I understand what you're saying, are you trying to transfer the contents of one drive to another blank one? If that is the case, you should be able to simply hook it up as a secondary and format it through File Explorer or Computer Management. Can you maybe take a screenshot of what you're looking at and what is grayed out?
Open Command Prompt
diskpart
list disk
Find the SSD you want to format. Let's assume it's disk 1.
select disk 1
clean
Select the disk and clean. This wipes all partitions currently on it. If you want to also securely erase the drive to prevent any of your old data that was on the drive to be recovered, use clean all. Clean all would take a while, maybe a few hours to complete.
create part pri
Create a primary partition on that drive.
select part 1
Select that newly created partition
format fs=ntfs quick
Format the partition to NTFS format.
assign
Assign a drive letter to your SSD. And you're done!
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
