Replacement for nvidia 940mx ?
Go to solution Solved by Speedbird,
11 minutes ago, xtoonx said:
HP-15-au 620 tx
@RTX 3090
After a quick Google search, it seems that the GPU is soldered onto the motherboard and therefore not upgradeable.
1 minute ago, xtoonx said:
HP product page mentions 'discrete'.
https://support.hp.com/in-en/document/c05306751
Discrete does not mean upgradeable. There is a separate chip, but it's soldered onto the motherboard. See the service manual for more details: http://h10032.www1.hp.com/ctg/Manual/c05228250
LTT's unofficial Windows activation expert.
