Budget (including currency): 2500
Country: USA
Games, programs or workloads that it will be used for: AAA, some MMO, and CAD
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): only PC. Parts no accessories or extra
So i had a idea of what I wanted but u wanted to hear advice. I was planning on going with the new 5800 and 6900xt when they come out. I went with the the 2TB SSD and no Hdd because that would be enough storage for a few years.
PCPartPicker Part List
CPU Cooler: Corsair iCUE H150i ELITE CAPELLIX 75 CFM Liquid CPU Cooler  ($189.99 @ Amazon)
Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) ATX AM4 Motherboard  ($203.69 @ Amazon)
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  ($134.99 @ Amazon)
Storage: Samsung 970 EVO Plus 2 TB M.2-2280 NVME Solid State Drive  ($299.99 @ Amazon)
Case: Lian Li Lancool II Mesh ATX Mid Tower Case  ($109.99 @ B&H)
Power Supply: Corsair RM (2019) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($124.99 @ Corsair)
Case Fan: Corsair LL120 43.25 CFM 120 mm Fans 3-Pack  ($110.99 @ Best Buy)
Total: $1174.63
Generated by PCPartPicker 2020-11-04 21:08 EST-0500
https://linustechtips.com/topic/1265277-build-advice/
- if you aren't set on that RAM's look I would look for some 4000mhz instead, 5000 series (by previews) seems to leverage the extra speed better than 3000 series.
- might end up wanting an 850+watt PSU depending on how power hungry the 5800 and 6900xt are, seeing how the RTX3000 series boosts with huge power spikes might be the same for the 6900xt but we'll have to wait for reviews to see how power supplies handle the card.
The best gaming PC is the PC you like to game on, how you like to game on it
https://linustechtips.com/topic/1265277-build-advice/#findComment-14180544
