Earlier this month a bought a MSI GForce GT 710 and installed it on my computer. I found out after booting it up, that the front panel audio wasn't working. I installed and uninstalled and reintalled the drive and got it to work with and audio jack through my moniter, but not throught the front or back panel audio. It wont show up in device maneger or any thing. I beleive upgrading to windows 10 could fix it because of the better settings, but i dont have the funds. If anybody could help it would be greatly apriciated
https://linustechtips.com/topic/1265208-audio-help/
What version of Windows are you running? if you're on 7 or 8, the upgrade to Windows 10 is still free and a tutorial can be found here.
If both front and back audio aren't working you could try unplugging the front audio connector from the motherboard and see if the back audio works. Maybe there is a short somewhere.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
https://linustechtips.com/topic/1265208-audio-help/#findComment-14179999
If I'm reading this correctly, it looks like you're using HDMI audio which would explain why your front panel audio doesn't work. Front panel runs off of your motherboard or dedicated sound card. The audio from your monitor would be coming from your GT 710 via HDMI.
So for me, I would have to switch my default device back to the Speakers (Conexant SmartAudio HD) for the headphone jack on my laptop to output any sound. If I have it on Intel(R) Display Audio, it would be sending the audio signal via HDMI to my monitor which my speakers are connected to.
 The same thing happens with my desktop but it's not on at the moment so this is closest example I can give.
4 minutes ago, B8C0N said:
Im on windows 7 pro
its not the board because with my old card it worked fine and the front usb still works
with windows 10 i feel guilty with having the watermark
Windows 10 Pro will activate with your existing Windows 7 Pro key
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1265208-audio-help/#findComment-14180016
2 minutes ago, B8C0N said:
the problem is alll that shows up is the hdmi audio even with disabled devices shown
Open Device Manager and see if you can see your onboard audio device. It should be either a Conexant or Realtek device if it's onboard audio. Your respective manufacturer if it's an add-in sound card.
https://linustechtips.com/topic/1265208-audio-help/#findComment-14180035
its not there
Then you need to install the Audio Driver for your motherboard. Go into Windows update, select Optional Updates and see if it had picked it up. Or better yet, go to the support page for your motherboard on the manufacturer's website and download the driver. Are you aware of the make and model of your board?
https://linustechtips.com/topic/1265208-audio-help/#findComment-14180050
