Budget (including currency): 1000 - 1300 usd
Country:  Kuwait (good but not 100% availability)
Games, programs or workloads that it will be used for:  1440p 144hz Gaming, Streaming, Video editing, Content creation
So I found this prebuilt and want to compare it to any of your lists, try to beat it I couldn't
https://www.amazon.com/CyberpowerPC-Supreme-Liquid-Gaming-SLC8260A3/dp/B08FSXT6D4/ref=pd_sbs_147_10?_encoding=UTF8&pd_rd_i=B08FSXT6D4&pd_rd_r=5fcd37e3-87a4-47ac-bfb2-f5b4f6c7ad3e&pd_rd_w=VF6ix&pd_rd_wg=xttNY&pf_rd_p=ed1e2146-ecfe-435e-b3b5-d79fa072fd58&pf_rd_r=4G2MF38A9TZQFCV51BGR&psc=1&refRID=4G2MF38A9TZQFCV51BGR
for 1300 dollars with a 3800x, AsRock 5700xt challenger pro, adata 16gb 3000mhz cl16 ram, AsRock b550 am (oem board), 1 tb nvme ssd, 120mm aio, wifi and windows 10 home, 6 usb 3.1 ports, 2 usb 2.0 ports
Do I buy it and upgrade later, or can someone make a list just as good?
https://linustechtips.com/topic/1265129-pre-built-vs-building/
3 minutes ago, boggy77 said:
can you ship that to Kuwait? how much would it cost?
buying locally might be cheaper.
anyway, for that budget, you should be able to get a 5600x and either a 3070 or a 6800, which would be much much better.
Can I fit a 5800x in there, oh and I missed 500 dollar shipping lol
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14179234
The problem is that it's not a good time to buy a GPU,and prices are too high on Amazon,
Anyway that pre-built is overpriced as well,and there are no graphics cards in Kuwait.
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14179244
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14179290
1 minute ago, boggy77 said:
300 dollars cheaper, that is 100 kd! wait I have aunts and cousins in america would it be cheaper if they get them and ship it to me with dhl or aramex?
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14179307
Wow it actually is reasonably cheaper with fedex by 50 kd
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14179360
Just be aware that you might have to pay taxes and import. I'm not sure how that all works there, but that might be why it's more expensive there.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14179385
I think fedex includes taxes, I don't know I'm new to this whole shipping thing
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14179436
What about this pc?:
https://www.amazon.com/dp/B07X1TZT85?psc=1&pf_rd_p=0341f622-1508-4712-8614-4588a55d8cf4&pf_rd_r=K9RH8VE4YXGY48NY8AQ8&pd_rd_wg=H1zAT&pd_rd_i=B07X1TZT85&pd_rd_w=6Je1S&pd_rd_r=4687e96f-f066-4731-a7b6-b34132a4f869&ref_=pd_luc_rh_ci_mcx_mr_huc_d_02_01_t_img_lh
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14179439
Thats not great. Here are the problems
-It's unbalanced. That 1660ti won't be taking advantage of the 3700x in gaming.
-Its going to run hella hot. That PC is running a stock cooler with a 3700x, which is pretty... well, bad. It also looks like it has minimal airflow.
-The ram speed is 2666mhz.
-That is just way too overpriced and just a pretty bad deal overall
Quote
geometry is hard
b550 > x570
https://linustechtips.com/topic/1265129-pre-built-vs-building/#findComment-14180455
