Trying to get a new build to work! I'll link my specs below first:
Case: NZXT H210
Motherboard: ASUS H370-i Gaming
CPU: Intel i5 9400F
GPU: GeForce GTX 1060 3GB
Memory: Avexir 2X4GB 2400Mhz DDR4 Ram
Storage: WD 1TB HDD, 500MB Samsung SSD
PSU: 500W System Power 9 Be Quiet
MY ISSUE is that I have the Razer Kraken Pro V2 and I'm using a headphone splitter to connect both mic and audio into the one front headset audio jack. Audio works great; crystal clear sound. But my mic refuses to work and constantly registers weird electronic jittering even when I just have the headphone jack plugged in. I've tried with another pair of earphones with no mic and the sound settings still say a mic is recording sound (it's the same electronic feedback noise).
Things I've tried:
- Both mobo and front i/o audio header are hd audio so no compatibility issues
- Replugged the AAFP connector into the mobo. The pins look undamaged so doesn't seem to be the issue
- Tried headphones on another computer; work just fine. No problems with headset.
- No debris on or around mobo AAFP pins2020-11-01 16-52-47 (online-audio-converter.com).wav
Not sure if I got unlucky with a faulty mobo, or the audio header specifically just has a faulty mic pin. Do I just buy a 3.5mm to USB converter? I've attached a screenshot of the sound settings when trying to troubleshoot (to show mic is constantly 'registering sound') and also an audio file of the sound I hear from it. Please help me!
https://linustechtips.com/topic/1264934-front-io-audio-aafp-problem/
Case: NZXT H210
CPU: Intel i5 9400F
Things I've tried:
I think you've got bad audio on your mobo and you're unlucky. Consider getting an amp/DAC combo if you NEED crystal sounding audio and mic input. The sound blaster G6 is an option.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
Thanks for the reply. I think I'm just going to invest in a cheap soundcard just so I can use my headset. Hopefully that'll bypass these audio issues.
For a more cheaper one you could get the Sound Blaster Omni. It is an external USB soundcard and has tons of features in the software as well.
AKG P420 Mic
Other peripherals
