Hi...
I'll get straight to the point. I created a Minecraft server using MInehut.org. I use TLauncher to play Minecraft Java Edition. I checked the server info and compatibility with MCJE is confirmed. However, I am not able to join it. Can someone please help me.
PS:
I play MCJE cuz my pc is kinda old.
Any better game suggestions are welcome.
Thank You
Quote
PC Specs (5 yo):
CPU: i3-3220
PSU: 450W, no eff rating
HDD: 1TB
RAM: 4GB DDR3-1600
GPU: Asus EN210 silent.
https://linustechtips.com/topic/1264811-problem-with-minecraft-server-connection/
How are you unable to connect to the server? What error does it give?
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
You're using the whole IP that the host gave you. Ports included right?
Should be say 000,00,000,0:0000
The numbers after the : matter and need to be there too.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
The port numbers actually don't have to be there unless it's another port than the default one
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
1 hour ago, Aditya K said:
i don't know the default port...
So I thought its a good idea to include it anyways
default port is 25565
Reminder⚠️
BTW is there some other free server hosting site which is not severely time limited?
I know server.pro is an okay site but you have to renew it every 60 minutes
Reminder⚠️
