Hello guys. Im building my first pc and I have some questions.  But first I'll say my specs  CPU (5000 series) still waiting to be released, Cpu cooler ( arctic freezer ii 360), storage (m.2 nvme wd 1tb) still waiting on my samsung 980 pro for faster storage, PSU ( Corsair rm850x), RAM ( G skill royal 2x 8gb 3600hz), Case (Lian li dynamic), Motherboard ( Asrock Taichi x570), GPU (RTX 2060 super).  I think that is everything.
So my question is, if I install everything and with out a cpu would the rams rgb light up? Or should I wait till I get my cpu (ryzen 5000 series)?  Only the Motherboards light will work but not the rams.  Im just trying to build it in advance so after I get my cpu it will be just plug and play.  Is that normal?  With out a cpu the rams won't light up.  But I haven't connected it to a monitor yet so I dont know yet if its working or not.
Thank you for your answer guys.   Sorry about my grammar.  Hopefully its understandable
https://linustechtips.com/topic/1264594-need-clarifications/
it wont display, or even post without the cpu, so i wouldn't bother with display. ram might light up without cpu, depends on the board, but i wouldn't give it a second thought until you try it with the cpu installed.
https://linustechtips.com/topic/1264594-need-clarifications/#findComment-14174860
