Just now, nevann_711 said:
i do not know how to do that would u please walk me through that
Remove the small battery then put it back in - It will reset all of the settings in the BIOS!!
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
Unplug the pc from the wall. Pull the small round battery out that is in this picture. Hold your power button down for ~10 seconds or so. Put battery back in. Plug into wall and turn on. Let us know what happens.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
what small battery i’m very confused
This battery:
how do i remove it safely?
ok well it’s a pre built and i have no idea how to put it together even tho i’ve watched countless videos
So don't touch it,i will think about something.
Do you get a fan spin in the graphics card?
Do you know what model the GPU is? MSI 1070, ASUS 2060 etc
Project Hot Box
Oppbevaring
2 minutes ago, nevann_711 said:
msi 2070 super
Can you post a good picture of how this is mounted in the case? The part that has the blue circle. I want to make sure it's in the correct slots.
Project Hot Box
Oppbevaring
i will once i get back home i’ve been very upset about it and decided to go get some food
Sounds good. I'm at work currently and off in half hour. I'll try to remember to check when I get outside. If not, hopefully Vishera is still around. If not I'll be on in the morning for sure.
Project Hot Box
Oppbevaring
i’ve never layed it on its side but i assume so why?
I need to know it,because if it does then it's probably has to do with how you mounted the GPU.
Because if the GPU is "twisted" and in the wrong slots, laying it on it's side will take weight off the twist and make it less drastic. Putting it in the correct slots would be ideal, but that's another way of checking this.
Project Hot Box
Oppbevaring
so should i lay it down and turn it on?
Just so you understand our thinking a little more. See how much lower the right side is than the left? A little of this sag is normal, but this seems like too much.
Inkedimage.jpg.1517ea10c04f34a3cc2ca30442eaa76d_LI.thumb.jpg.ae41fd3913eda3910ca88670e0fc86c4.jpg
Project Hot Box
Oppbevaring
ever since i’ve had it it’s always sagged idk why it cant support itself but it’s never stopped it from working
