Posted November 2, 2020 i had to move my pc for about a week and i’ve set it all up and now i cannot get an hdmi signal to go out to my monitor I plugged my monitor to an xbox and the picture pops up but when i plug it into the pc it says “hdmi 1 signal not found” PLEASE SOMONE HELP i unplugged gpu to see if it was that still same problem and same with ram IMG_1610.MP4 Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2020 Author didn’t even notice the train if anyone needs more videos let me know please Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174536 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2020 Author all fans run heat sync lights up just no hdmi out and I live in the middle of no where so I wouldn’t even know where to take this Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174543 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2020 Reseat the GPU, RAM and all cables since you moved it and try again. What CPU is under that cooler? It looks like this connector isn't in all the way. Spoiler I'm not actually trying to be as grumpy as it seems. I will find your mentions of Ikea or Gnome and I will /s post. Project Hot Box CPU 13900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU Zotac RTX 4090 Trinity OC, Case Fractal Pop Air XL, Storage Sabrent Rocket Q4 2tb, CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR HX1000i, Cooling Corsair XC8 CPU block, Bykski GPU block, 360mm and 280mm radiator, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR Oppbevaring CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPUs Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, Case Mining Frame, 2x Storage Samsung 860 Evo 500 GB, PSU Corsair RM1000x and RM850x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans Why is the 5800x so hot? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174548 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2020 1 minute ago, Voluspa said: Reseat the GPU, RAM and all cables since you moved it and try again. What CPU is under that cooler? Like Voluspa said reseat everything and try different HDMI outputs on the back of the graphic card Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174556 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2020 you're not hooked up to the motherboard video ports right? I WILL find your ITX build thread, and I WILL recommend the SIlverstone Sugo SG13B Primary PC: i7 8086k - EVGA Z370 Classified K - G.Skill Trident Z RGB - WD SN750 - Jedi Order Titan Xp - Hyper 212 Black (with RGB Riing flair) - EVGA G3 650W - dual booting Windows 11 and Fedora Linux - Black and green theme, Razer brainwashed me. Draws 400 watts under max load, for reference. PSU tier list How many watts do I need? PSU misconceptions, protections explained, group reg is bad Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174562 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2020 Author AMD Ryzen 7 3700X 8-Core 3.6GHz what do u mean reseat it? i got this prebuilt from nzxt in January i seated ram and gpu i tried 3 different hdmi cables and what do u mean video ports Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174623 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2020 Just now, nevann_711 said: AMD Ryzen 7 3700X 8-Core 3.6GHz what do u mean reseat it? i got this prebuilt from nzxt in January i seated ram and gpu i tried 3 different hdmi cables and what do u mean video ports Make sure you quote people when you reply. I just happened to still have this thread open so I saw the notification. It's the button with the one arrow at the bottom left of this post. Unplug and plug back in. Was that connector on the GPU in all the way? On the back of your computer, where is your monitor plugged in? Up by the USB ports or down low? I'm not actually trying to be as grumpy as it seems. I will find your mentions of Ikea or Gnome and I will /s post. Project Hot Box CPU 13900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU Zotac RTX 4090 Trinity OC, Case Fractal Pop Air XL, Storage Sabrent Rocket Q4 2tb, CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR HX1000i, Cooling Corsair XC8 CPU block, Bykski GPU block, 360mm and 280mm radiator, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR Oppbevaring CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPUs Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, Case Mining Frame, 2x Storage Samsung 860 Evo 500 GB, PSU Corsair RM1000x and RM850x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans Why is the 5800x so hot? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174631 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Author The gpu connectors were plugged in before and i removed the whole thing and re did it and all the connectors clicked in Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174641 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 1 minute ago, nevann_711 said: The gpu connectors were plugged in before and i removed the whole thing and re did it and all the connectors clicked in You forgot to quote, but you just plugged into the wrong spot on your computer. Where you have it now is trying to use an integrated GPU, which your CPU doesn't have. Plug it in down low. It'll look different, but you're looking for something down low and parallel to the desk. It'd be roughly where the "VGA socket of add-in graphics card" is in this graphic. I'm not actually trying to be as grumpy as it seems. I will find your mentions of Ikea or Gnome and I will /s post. Project Hot Box CPU 13900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU Zotac RTX 4090 Trinity OC, Case Fractal Pop Air XL, Storage Sabrent Rocket Q4 2tb, CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR HX1000i, Cooling Corsair XC8 CPU block, Bykski GPU block, 360mm and 280mm radiator, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR Oppbevaring CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPUs Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, Case Mining Frame, 2x Storage Samsung 860 Evo 500 GB, PSU Corsair RM1000x and RM850x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans Why is the 5800x so hot? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174650 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Author 5 minutes ago, nevann_711 said: The gpu connectors were plugged in before and i removed the whole thing and re did it and all the connectors clicked in 2 minutes ago, Voluspa said: You forgot to quote, but you just plugged into the wrong spot on your computer. Where you have it now is trying to use an integrated GPU, which your CPU doesn't have. Plug it in down low. It'll look different, but you're looking for something down low and parallel to the desk. It'd be roughly where the "VGA socket of add-in graphics card" is in this graphic. I tried that and still didn’t work also when i turn my pc on now my keyboard connects and then flashes off then back on Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174659 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Just now, nevann_711 said: I tried that and still didn’t work also when i turn my pc on now my keyboard connects and then flashes off then back on Make sure these two cables are in all the way. The one on the left looks pulled out a little. I'm not actually trying to be as grumpy as it seems. I will find your mentions of Ikea or Gnome and I will /s post. Project Hot Box CPU 13900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU Zotac RTX 4090 Trinity OC, Case Fractal Pop Air XL, Storage Sabrent Rocket Q4 2tb, CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR HX1000i, Cooling Corsair XC8 CPU block, Bykski GPU block, 360mm and 280mm radiator, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR Oppbevaring CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPUs Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, Case Mining Frame, 2x Storage Samsung 860 Evo 500 GB, PSU Corsair RM1000x and RM850x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans Why is the 5800x so hot? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174662 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Author 3 minutes ago, Voluspa said: Make sure these two cables are in all the way. The one on the left looks pulled out a little. it’s in all the way 62605521478__40C634BA-0299-4637-9B8C-739A2A35B1A4.MOV Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174667 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 21 minutes ago, nevann_711 said: it’s in all the way 62605521478__40C634BA-0299-4637-9B8C-739A2A35B1A4.MOV Can you post a picture of the whole back of your PC? I want to see where you moved the monitor cable to and all the other slots back there. @Visherathis is the video I was talking about. Something isn't in all the way.... I'm not actually trying to be as grumpy as it seems. I will find your mentions of Ikea or Gnome and I will /s post. Project Hot Box CPU 13900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU Zotac RTX 4090 Trinity OC, Case Fractal Pop Air XL, Storage Sabrent Rocket Q4 2tb, CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR HX1000i, Cooling Corsair XC8 CPU block, Bykski GPU block, 360mm and 280mm radiator, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR Oppbevaring CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPUs Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, Case Mining Frame, 2x Storage Samsung 860 Evo 500 GB, PSU Corsair RM1000x and RM850x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans Why is the 5800x so hot? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174668 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Wrong place to connect the HDMI... 12 minutes ago, nevann_711 said: The gpu connectors were plugged in before and i removed the whole thing and re did it and all the connectors clicked in Should listen to that one: 3 minutes ago, Voluspa said: Make sure these two cables are in all the way. The one on the left looks pulled out a little. A PC Enthusiast since 2011 AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58 Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174673 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Author 1 minute ago, Voluspa said: Can you post a picture of the whole back of your PC? I want to see where you moved the monitor to and all the other slots back there. Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174674 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Author 2 minutes ago, Vishera said: Wrong place to connect the HDMI... Should listen to that one: it says hdmi right where it’s at would u tell me where to put it? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174680 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 2 minutes ago, nevann_711 said: Can you do a picture of the motherboard and the connections on it also? @Visherait was a little confusing, but he did move the HDMI to the GPU and he did post a video and that plug is in fact all the way in. I'm not actually trying to be as grumpy as it seems. I will find your mentions of Ikea or Gnome and I will /s post. Project Hot Box CPU 13900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU Zotac RTX 4090 Trinity OC, Case Fractal Pop Air XL, Storage Sabrent Rocket Q4 2tb, CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR HX1000i, Cooling Corsair XC8 CPU block, Bykski GPU block, 360mm and 280mm radiator, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR Oppbevaring CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPUs Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, Case Mining Frame, 2x Storage Samsung 860 Evo 500 GB, PSU Corsair RM1000x and RM850x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans Why is the 5800x so hot? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174681 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Author 1 minute ago, Voluspa said: Can you do a picture of the motherboard and the connections on it also? @Visherait was a little confusing, but he did move the HDMI to the GPU and he did post a video and that plug is in fact all the way in. they’re all plugged in as well Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174685 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Connect the monitor to the leftmost input on your video card. MacBook Pro 16 - i9-9980HK - Radeon Pro 5500m 8GB - 32GB DDR4 - 2TB NVME iPhone 12 Mini / Sony WH-1000XM4 / Bose Companion 20 Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174687 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Just now, nevann_711 said: it says hdmi right where it’s at would u tell me where to put it? Like in here: Just now, nevann_711 said: I have a feeling that something isn't connected properly. A PC Enthusiast since 2011 AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58 Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174690 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 2 minutes ago, nevann_711 said: they’re all plugged in as well Does the whole graphics card "push" into the motherboard more? It looks like it's sagging a lot. Don't use a lot of force, just be firm with it. You'll feel it if it's not all the way in. I'm not actually trying to be as grumpy as it seems. I will find your mentions of Ikea or Gnome and I will /s post. Project Hot Box CPU 13900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU Zotac RTX 4090 Trinity OC, Case Fractal Pop Air XL, Storage Sabrent Rocket Q4 2tb, CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR HX1000i, Cooling Corsair XC8 CPU block, Bykski GPU block, 360mm and 280mm radiator, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR Oppbevaring CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPUs Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, Case Mining Frame, 2x Storage Samsung 860 Evo 500 GB, PSU Corsair RM1000x and RM850x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans Why is the 5800x so hot? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174695 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Author 2 minutes ago, Vitamanic said: Connect the monitor to the leftmost input on your video card. what do u mean? on my monitor the hdmi is on hdmi 1 and that’s the only hdmi option Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174697 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 Author Just now, Voluspa said: Does the whole graphics card "push" into the motherboard more? It looks like it's sagging a lot. Don't use a lot of force, just be firm with it. You'll feel it if it's not all the way in. yup it’s pushed in all the way Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174698 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 3, 2020 3 minutes ago, Vishera said: Like in here: I have a feeling that something isn't connected properly. That or it got shut down weird and CMOS might need cleared. I'm not actually trying to be as grumpy as it seems. I will find your mentions of Ikea or Gnome and I will /s post. Project Hot Box CPU 13900k, Motherboard Gigabyte Aorus Elite AX, RAM CORSAIR Vengeance 4x16gb 5200 MHZ, GPU Zotac RTX 4090 Trinity OC, Case Fractal Pop Air XL, Storage Sabrent Rocket Q4 2tb, CORSAIR Force Series MP510 1920GB NVMe, CORSAIR FORCE Series MP510 960GB NVMe, PSU CORSAIR HX1000i, Cooling Corsair XC8 CPU block, Bykski GPU block, 360mm and 280mm radiator, Displays Odyssey G9, LG 34UC98-W 34-Inch,Keyboard Mountain Everest Max, Mouse Mountain Makalu 67, Sound AT2035, Massdrop 6xx headphones, Go XLR Oppbevaring CPU i9-9900k, Motherboard, ASUS Rog Maximus Code XI, RAM, 48GB Corsair Vengeance LPX 32GB 3200 mhz (2x16)+(2x8) GPUs Asus ROG Strix 2070 8gb, PNY 1080, Nvidia 1080, Case Mining Frame, 2x Storage Samsung 860 Evo 500 GB, PSU Corsair RM1000x and RM850x, Cooling Asus Rog Ryuo 240 with Noctua NF-12 fans Why is the 5800x so hot? Link to comment https://linustechtips.com/topic/1264561-pc-problems-urgent-help/#findComment-14174700 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
