I've been a PC gamer for as long as I can remember but due to unavoidable circumstances I had to sell my desktop and settle for a laptop. Gaming laptops aren't widely available in my country. Acer Nitro 5 (2020) was the only viable option within my budget. Now, I know that the Nitro series is notorious for its overheating tendencies but a lot of people assured me that the cooling was significantly improved in the 2020 model but my experience says otherwise.
When I first got it, the idle temps hovered around 65-70C (plugged in, HP mode, normal fan speed). During gaming, the temps would spike to 92C and thermal throttle the CPU. I compared a lot of benchmarks and figured out that I was getting way less performance than I should, due to the throttling. Undervolting isn't allowed on 10th gen chips either (Some laptops can still do it, but not Acer). For some reason, getting a laptop cooler didn't make any difference as well. The peak temps would still be 92-93C. Some YouTube videos showed significant temp drops after repasting the CPU and GPU so I opted for that. I had some leftover Arctic MX-4 from my desktop gaming days. I opened up the laptop and repasted. Initially, I saw 2-3C drop in the temps, specially in the first few days. After a week or so, it was just as before. The same temps as before, the same performance drop. But, the main issue started after a month or so. The temps got worse than ever before. Now, during gaming, the temps go up to 94-95C and throttle like crazy.
I don't even get 110 FPS in Valorant, or 65-70 FPS in GTA V while other 1660ti benchmarks show 250+ FPS in Valorant and 80-90 in GTA V.
The lag is so crazy that I can't run Discord alongside any other game. I have to close everything running in the background to get a seemingly smooth experience in FPS games. If I keep the laptop running for more than 8-9 hours, even Windows animations start lagging.
Spec:
Acer Nitro 5 (2020)
i7-10750H
16GB DDR4 - 2133
GTX 1660ti
512GB NVMe
1080p 144Hz panel
Note: All the temps I mentioned are on HP mode, max fan speed.
Note: Throttlestop or Intel XTU don't make any difference. Those are disabled on the 10th gen chips. The Throttlestop speedshift helps the temps but the performance doesn't improve at all.
Note: Should I try repasting again? The paste I applied first time was pretty old (more than a year or so), could that be the reason for temp spikes again?
Note: The vendor I got it from said I wouldn't be eligible for warranty if I repasted. So, that's not an option either.
i7-3770k @ 4.5 GHz
Asrock Z77 Extreme4
16GB DDR3 Corsair Ballistix RGB
Zotac 1070 Amp Extreme
1TB Western Digital
128GB ADATA SU800
630W Thermaltake Smart SE
https://linustechtips.com/topic/1263657-laptop-cooling-disaster/
you got a lemon, send back for warranty service (don't tell them you repasted of course)
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
That's the thing. Sending something to warranty is a nightmare in my country. It'd take around 1.5-2 months for the whole procedure to end and I have heard people receiving "Warranty not eligible" notice after waiting that long and getting the same lemon back. So, I was trying to avoid that.
i7-3770k @ 4.5 GHz
Asrock Z77 Extreme4
1TB Western Digital
128GB ADATA SU800
