Right so I'm playing the new watchdogs game, I'm getting under 60fps as a general rule which I thought was pretty low for a 1660s and r5 2600, so I check my usage in task manager and CPU usage all looks okay: between 60 and 80. However my GPU usage will very rarely go over 15% usage, does anyone have any advice?
https://linustechtips.com/topic/1263197-high-cpu-low-gpu/
I want to note the new watchdogs game is apparently running terrible on a ton of systems at the moment.
CPU- Ryzen 9 3900x
CPU Cooler- Artic Liquid Freezer 2 240mm
GPU-  GIGABYTE AORUS GeForce RTX 3070 Ti Master 8G
RAM- CORSAIR VENGEANCE RGB PRO 32GB 3200Mhz
PSU- Cooler Master MasterWatt 650 Watt
HDD- WD Blue 4TB x2
SSD- 1TB WD Blue SN550 NVMe
Case- Custom Made Desk
Motherboard- ASUS ROG Strix B450-F Gaming
Microphone- Blue Snowball Ice
Headphones- Razer Nari Ultimate
Webcam- Logitech c270
Monitors- MSI Optix MAG24C and Acer KA240HQ Abid
Mouse- Corsair Nightsword RGB
Keyboard- Corsair K95 RGB Platinum MX Speed
https://linustechtips.com/topic/1263197-high-cpu-low-gpu/#findComment-14163528
17 minutes ago, GoodEnough said:
what api/api's does the game run in?
im just a little curious
idk I've just seen some threads online, i don't have the game
CPU- Ryzen 9 3900x
HDD- WD Blue 4TB x2
https://linustechtips.com/topic/1263197-high-cpu-low-gpu/#findComment-14163558
1 minute ago, bqrc said:
Ah ok that makes me feel a little better
as of right now playing the game is like trying to play minecraft with 300 mods with only 16gb of ram, (say goodbye to your ram if your playing modded minecraft)
minecraft + shaders + 300 mods + only 16gb of 3000mhz ram = less than 60 fps at 6 chunks
https://linustechtips.com/topic/1263197-high-cpu-low-gpu/#findComment-14163583
