Replacement Case Recommendations
Guest Emrye
Whoops, forgot to change that. I have an R7 260X.
260x doesn't put off enough heat to warrant a case change.  with money being limited for you, I'd just stick with this case.  buy some games or something either the money instead
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti | Samsung 840 Pro 256GB | OCZ Agility 3 480GB | ADATA SP550 960 GB
Corsair AX860i | CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
You obviously haven't seen my cable management.
zipties are your friend
Grey with blue, as blue is my main color for my build.
That is beautiful. So you have it? How's the cable management?
sorry cant comment on cable management. seems like from some pictures you should have no issues tucking wires behind the mobo. the side panel has punch out. also guy mentioned in this video about cable management.
https://www.youtube.com/watch?v=yjx_VBbi_zU at 4:25
I would think its pretty decent. My z9plus has decent cable management tie downs.
also at thinkcomputers you can judge if this this satisfies your needs for cable management
http://www.thinkcomputers.org/zalman-ms800-mid-tower-case-review/4/
Amd fx-8320 oc 4.1ghz, 8gb ram, gtx 780ti 3gb, 240gb ssd, 1.5tb hdd,
NXZT Source 530 is another solid pick. Total Mesh front panel, nice big window side panel, Fan Hub + Controller, and lots more for around 80 dollars
Motherboard: Asus ROG Crosshair VIII Hero (Wi-Fi) | CPU: AMD Ryzen 9 3900X | Memory: 32GB 3600mhz DDR4 | GPU: EVGA GTX 1080 Ti FTW3 |
Storage: Samsung 840 Pro 256gb, 850 Evo 500gb, 960 Pro 1tb | Cooling: Custom Liquid Cooling Loop (CPU/GPU) | Case: CaseLabs Mercury S8+Pedestal  | Monitors: Asus ROG Swift PG279Q + PA238QR
Other option is save a few more $$$ and wait for corsair' new case or do some of the other upgrades in the meantime.
i5-3570k @ 4.4ghz (1.240v) || Asrock extreme 4 || CM Hyper 212 evo
Samsung 840 || WD blue 1tb || WD green 1tb || Powercolor 7870 xt @ (1200 mhz core : 1500 mhz mem)
Powered by a silverstone strider 500w psu in a NZXT 210.
