Custom loop problem
Go to solution Solved by MiszS,
Just now, Francisco E said:
They are both 100%
100% from the start? If so, idk what is it, maybe there is an air pocket in the thermal paste
So I have a custom loop that I made myself but the problem is the temps are high while gaming it hits around 60-70 Celsius on a Ryzen 7 5700x. The cpu is not even over clocked so it’s just 65 watts. Its idle temp is 50 Celsius which is also high. The specs of the custom is a Corsair XR5 240mm rad a Corsair hydro x xc7 water block and this pump Yosoo SC-300T DC 12V Ultra-Quiet Water Cooling Pump 4W Reservoir max.300L/h for PC CPU Liquid Cooling System. The liquid is also Corsair also for the thermal paste. Ambient temperature is 22 Celsius for my room. I posted a picture below. I have tried everything from changing pump speed to fan speed and bought more fans. image.thumb.jpg.bcfb2d7ffe9a7a7aaa61e4e3bbba2e62.jpg
https://linustechtips.com/topic/1574572-custom-loop-problem/
2 minutes ago, MiszS said:
70 degrees max seems fine to me, considering its just a 240mm loop. The idle temp seems high, but it's not the cooling's fault, but whatever you have running in the background
When it idles at 50c I usllay don’t have anything running and I’ve seen other 240 running better than this. Could it be the pump?
https://linustechtips.com/topic/1574572-custom-loop-problem/#findComment-16447753
Nothing, as how much nothing? What startup apps do you have, and how much cpu is used at idle?
https://linustechtips.com/topic/1574572-custom-loop-problem/#findComment-16447755
So it seems like there are little pockets of air it looks like when i was adding the thermal paste I didn’t add enough paste or not enough pressure. I’ll repaste it and give you the results.
https://linustechtips.com/topic/1574572-custom-loop-problem/#findComment-16447783
1 hour ago, Francisco E said:
Seems the cooler wasn't fully screwed and didn't make good contact, the paste seems not much "crushed"/spread
https://linustechtips.com/topic/1574572-custom-loop-problem/#findComment-16447834
