SSD speed difference
Go to solution Solved by AndreiArgeanu,
2
My thought is, its not even launched yet.
Why not ask this when those things are released.
Until then im like, dont bother. But when launched i wanna know that too. And we will, just have patience. (altho easier said then done).
Or should i get my crystal ball again, and give you some peak into the future, just know its not cheap. 😛
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
https://linustechtips.com/topic/1262663-ssd-speed-difference/#findComment-14158482
Just realised we have to wait for Microsoft's direct storage API, :( get ready for a new subscription
https://linustechtips.com/topic/1262663-ssd-speed-difference/#findComment-14158502
Yes but before you know you need Gen5...
https://linustechtips.com/topic/1262663-ssd-speed-difference/#findComment-14158520
