3 minutes ago, Mahmudul Hasan said:
I have the same issue with my current G. Skill Trident Z 3200 Mhz 16 GB single stick RAM. What can I do to resolve this issue?
most often culprit is xmp, as its not perfect (although it works perfectly fine for me), so it could just be the ram
if your running 3200mhz then try this
16, 18, 18, 18, 36
Voltage 1.35
also its 3:30 am and im going to bed
https://linustechtips.com/topic/1262583-problem-with-ram/#findComment-14157700
16, 18, 18, 18, 36
Voltage 1.35
I see. Can you please help me with where can I configure this setting and how to do it?
https://linustechtips.com/topic/1262583-problem-with-ram/#findComment-14157708
Split off in to its own thread. Do not hijack other peoples posts asking for help. If you require help make your own post.
https://linustechtips.com/topic/1262583-problem-with-ram/#findComment-14157813
