So, my friend was having some problems booting his PC. It took almost 5 minutes to fully boot. We did some tests and found out his HDD seems to be dying, but I don't want to recommend him buying a new one without making sure the HDD is really the problem. Here are the S.M.A.R.T. test results. I really don't know much about those numbers, so I'm asking for help.
HDDScan S.M.A.R.T. Report
HDD
State: Green.ico
Model: ST1000DM010-2EP102
Firmware: CC43
Serial: Z9AHN2CG
LBA: 1953525168 (1000 GB)
Report By: HDDSCAN v4.1
Report Date: 27/10/2020 13:01:00
  Num Attribute Name Value Worst Raw(hex) Threshold
Green.ico 001 Raw Read Error Rate 080 054 0000000628-A7F0 006
Green.ico 003 Spin Up Time 097 097 0000000000-0000 000
Green.ico 004 Start/Stop Count 099 099 0000000000-0739 020
Green.ico 005 Reallocation Sector Count 100 100 0000000000-0000 010
Green.ico 007 Seek Error Rate 089 060 00000033E6-6AC7 045
Green.ico 009 Power-On Hours Count 090 090 0000000000-22E1 000
Green.ico 010 Spin Retry Count 100 100 0000000000-0000 097
Green.ico 012 Device Power Cycle Count 099 099 0000000000-06FB 020
Green.ico 183 SATA Downshift Error Count 100 100 0000000000-0000 000
Green.ico 184 End To End Error Count 100 100 0000000000-0000 099
Green.ico 187 Reported Uncorrectable Error 001 001 0000000000-0410 000
Green.ico 188 Reported Command Timeouts 100 099 0000000000-0002 000
Green.ico 189 High Fly Writes 100 100 0000000000-0000 000
Green.ico 190 Airflow Temperature 071 056 29 C 040
Green.ico 190 Airflow Temperature Minimum 071 056 21 C 040
Green.ico 190 Airflow Temperature Maximum 071 056 32 C 040
Green.ico 193 Load/unload Cycle Count 100 100 0000000000-0739 000
Green.ico 194 HDA Temperature 029 016 29 C 000
Green.ico 194 HDA Temperature Minimum 029 016 16 C 000
Green.ico 194 HDA Temperature Maximum 029 016 84 C 000
Green.ico 195 Error Rate 001 001 0000000628-A7F0 000
Green.ico 197 Current Pending Errors Count 100 100 0000000000-0000 000
Green.ico 198 Uncorrectable Errors Count 100 100 0000000000-0000 000
Green.ico 199 UltraDMA CRC Errors 200 200 0000000000-0000 000
Green.ico 240 Heads Flying Hours 100 253 2306C20000-22DD 000
Green.ico 241 Total Host Writes 100 253 000012342B-72DF 000
Green.ico 242 Total Host Reads 100 253 000029C6A3-A85A 000
https://linustechtips.com/topic/1262307-hdd-boot-problem/
