Replacement for my logitech G613
Go to solution Solved by jaslion,
18 minutes ago, StrawberryShortCakes said:
Well I find the switches too slow. Any suggestions?
I like my sharkoon purewrite xl. Because these are low profile khali red switches (the low profile part is what I wanted) very pleasant typing experience and they now have a rgb one that allows you to put it in white (mine is stuck on blue).
Well I destroyed myG613, I need a replacement keyboard.
Budget $99 - $130 usd
Needs
1 or 2 usb pass thru
Liner key switches or something like the silver keys in hyper x alloy fps se
Media keys if possible
White backlight/ rgb set to white
Silent Cerberus - Fractal Design Core500,Ryzen R7 3700x,Scythe Fuma 2,Gigabyte Aorus B550i Pro AX,Crucial Ballistix Elite 3200mhz cl16 16gb,Adata XPG SX8200 nvme 512gb m.2 ssd,Lexar NS100 1tb ssd,Red Dragon RX5700 8gb(bio flashed 5700xt),Corsair SF600 SFX 600w 80+ platinum F-Modular.
Hades - dO.Ob Look into my eyes and see the dark eternal abyss that is your soul and pay for your hidden sins.
Cerberus - the hell hound that guards the gates of hell. Once you enter you'll never escape.
https://linustechtips.com/topic/1262299-replacement-for-my-logitech-g613/
5 hours ago, jaslion said:
Another g613 if it ain't broke (in case of using it for you :p) don't fix it.
Nice thanks will check.
