Hub for fans???
Go to solution Solved by WoodenMarker,
16 minutes ago, DavidDuran said:
I'm in Mexico. Budget is not a problem. Fans are Pure Wings 2 by be quiet, 3 pin.
I do want them to change speed and... that's it. Cable management: just functional, nothing fancy.
Are you using the same fans for the cpu cooler?
In that case, go for basic non-powered fan splitters. 2-4 way splitters like these would work fine.
https://www.newegg.com/global/mx-en/black-en-lab-10-inch-25cm-fan-power-splitter-cable/p/1W7-005X-00033?Item=9SIACJF76E3833
https://www.digitalife.com.mx/producto/53474/Cable-Splitter-ventiladores-SPLI3FAN-1x-4-pin-Hembra-a-3x-4-pin-Macho-Negro-SPLI3FAN
Hello everybody,
this is my first time building a pc since 2012, so... everything is new for me.
I'm waiting for 6 Pure Wings 2 fans by be quiet! to arrive and I have an Aorus Elite B450 motherboard.
I'm not sure if I should buy a hub, splitter or anything similar to connect them to the motherboard or if I can do it without that.
Could you help me?
Thanks a lot.
https://linustechtips.com/topic/1261967-hub-for-fans/
Where are you shopping / located? Budget? What case and fans are you using? Are they 3 or 4pin?
Whether a hub or splitter is preferred would depend on your preferred style of cable management or fan control.
https://linustechtips.com/topic/1261967-hub-for-fans/#findComment-14153107
https://linustechtips.com/topic/1261967-hub-for-fans/#findComment-14153378
https://linustechtips.com/topic/1261967-hub-for-fans/#findComment-14153402
16 minutes ago, WoodenMarker said:
Thank you very much!! 😀😀
https://linustechtips.com/topic/1261967-hub-for-fans/#findComment-14153422
