So heres the pc im going to get but idk what to do for wifi since my router is not near where im going to put it and the motherboard doesnt have an pci e-key slot. Thanks!
https://linustechtips.com/topic/1261947-wifi-help/
THe Mobo will only have a PCIe key slot for wifi if it has on board support. Just get a PCIe full size one for Wifi.
https://pcpartpicker.com/products/wireless-network-card/
Edited by SlashedM
added link
Chicago Bears fan, Bear Down
https://linustechtips.com/topic/1261947-wifi-help/#findComment-14152436
well your could run a long cable.
or there are wifi cards that go into the 1x slot. or use a usb one.
https://www.overclockers.co.uk/asus-pce-ac88-dual-band-wireless-ac3100-pci-e-adapter-nw-105-as.html?gclid=EAIaIQobChMI54aS-OXS7AIVh63tCh1HJQbvEAQYAiABEgLjfvD_BwE this is my one, its way to expensive but was my best option. old house with stone walls I can't drill though
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1261947-wifi-help/#findComment-14152441
What about this one it has bluetooth and wifi 6?
https://www.amazon.com/Network-PCIE-Wifi-6-Card-dp-B089FCX3C3/dp/B089FCX3C3/ref=dp_ob_title_ce
https://linustechtips.com/topic/1261947-wifi-help/#findComment-14152451
what do you think about this one
https://linustechtips.com/topic/1261947-wifi-help/#findComment-14152459
@Kurferix
it looks fine, though (a little expensive) do look for some reviews.
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1261947-wifi-help/#findComment-14152750
