Howdy!
I've just put together a new tower, and cannot get the sucker to post. Spec below:
MOBO: ASUS AM4 TUF GAMING X570-Plus ATX
CPU: AMD Ryzen 9 3900X
RAM: Corsair Vengeance LPX 32GB (2X16GB) DDR4 3200 (PC4-25600) C16 1.35V
SSD: addlink S70 512GB SSD NVMe PCIe 3x4 M.2 2280
GPU: Two Radeon R9 290X (Reused from previous build w/ bad mobo, could not independently confirm working)
PSU: Seasonic 850w (Reused from previous build)
Monitor: Monoprice Zero-G Gaming Monitor - 27 Inch, WQHD With AMD FreeSync, 2560x1440p@144Hz, 1ms, HDR, 400nits, TN
OS: Will eventually be Windows 10 Home 64 bit, but haven't gotten that far yet.
Everything powers up, green LED (for Boot), no post. I try both DIsplay Port and HDMI out of the monitor into the motherboard and both GPU slots, no luck.
I confirm all cables are plugged in.  My motherboard CPU power has an option for an additional 4-pin but my power supply only has an 8-pin.  Some internet research reveals that the extra 4-pin is only needed for overclocking.
I try every possible configuration of RAM, including a single in A2, no luck (this memory is new, so likely not the culprit.
Yes, the CPU has plenty of thermal paste and is seated correctly.
I try booting with no GPUs, in addition to the Green Boot error, I also get a white VGA error.
I try the GPUs one at a time in each slot, checking both mobo & GPU ports with HDMI & DP, just the green Boot error and still no post.
The only thing I can think is that BOTH of these GPUs, recycled from an old BTC miner, are bust.  That would be a real shame, so I'm hoping y'all can point out something I've missed.
Many thanks!
https://linustechtips.com/topic/1261736-pc-powers-on-no-post-please-help/
Welcome to the forums!!!
There are no integrated GPUs in the 3900X, so thus you will get a VGA error because there is no VGA.
Do you have another graphics card laying around besides the two R9 290Xs?
Is there anything on the SSD (addlink S70) or is it completely new?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
It does sound like these are bad.
Are all the other components new other than these and the PSU?
This doesn seem like a power issue so i would suspect the video cards themselves.
And the onboard port wont work as mentioned above, no graphics in the CPU.
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
Sadly not, if I did I'd be using it.
SSD is brand new.
Everything else is new.
Thanks for the insight, y'all.  Looks like my concerns are validated and I'll have to get a new gpu.
I agree, good luck. Come back and let us know if that fixed it, if you think about it. 🙂
Family machines
