Am trying to get a 7970 Lightning Boost Edition and then watercool it (EK has a block for it), does anyone know of somewhere I can find one of these as the only places i have found are either silly money like £500 or on "pre-order" with an unknown arrival date.  Would appreciate any alternatives (7970 GHz cards only though), budget is £400 max.
https://linustechtips.com/topic/12615-7970-lightning/
http://www.ebay.co.uk/itm/msi-7970-lightning-/161017746484?pt=UK_Computing_Computer_Components_Graphics_Video_TV_Cards_TW&hash=item257d67d434
Not sure how you feel about ebay but this might be of interest to you, I don't think it's the boost edition but I'm not sure if they are in circulation yet. Any reason you specifically want the Lightning edition?
NZXT Phantom, i5 2500K @ 4.2Ghz, Noctua NH-C-14, ASUS P8Z77-V
EVGA 780 Classy, 8GB Corsair Vengeance LP 1600Mhz
120GB SSD, 2x 1TB WD Black (RAID 0), CM Silent Pro 700W, Win 7 Pro 64 Bit.
https://linustechtips.com/topic/12615-7970-lightning/#findComment-134792
Yeah not too great a fan of buying components off ebay.  The boost edition has a GHz edition GPU and has a higher clock and memory afaik.  Also am going to watercool/overclock the card in 3-6 months time so wanted a card which would handle it well.
https://linustechtips.com/topic/12615-7970-lightning/#findComment-134924
