Laptop to dual monitor with only 1 HDMI cable
Someone05
I'm using a Predator Helios 300 G3-571 for work / games and just bought a second monitor. The laptop uses a weird USB type C port that doesn't support display so that leaves me with just a HDMI port. The monitors are both AOC C27G1 27" Curved and have 2 HDMI ports, IN and OUT display ports and a VGA port.
My question what is the best way to connect them.
Should I get a USB 2.0 to HDMI adapter?
Should I get a HDMI to DisplayPort adapter and daisy chain the monitors?
Can I get a HDMI splitter?
Is there another way I don't know about?
The pictures are the laptop physical connections and the monitor specs and ports.
Thank you for any responses
