I've been getting fps drops lately especially on CSGO and valorant, even with just the game open, Is There something I need to upgrade or change on my rig?
MOBO:Aorus x299 ultra gaming pro
CPU : Intel® Core™ i9-7940X X-series Processor
RAM : Gskill Trident z 32gb Rgb Ram
GPU : GTX 1080ti Videocard Corsair
PSU : Rm850 Powersupply
HDD & SSD : 2TB SEAGATE Intel M.2 512gb SSD 6
Watercooling mods : Full Bykski Watercooling Peripherals and RGB fans
https://linustechtips.com/topic/1260951-fps-drops-on-a-i9-machine/
Welcome to the forums!!!
Are your graphics drivers up to date?
How are your system temperatures and CPU/GPU utilizations?
Do you have a lot of background applications running?
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Are your graphics drivers up to date? - Yes I always update them everytime I get new ones
How are your system temperatures and CPU/GPU utilizations? MY temp is usually at 45-59C
Do you have a lot of background applications running? No, I usually have my discord, chrome and the game I play open
I agree with all of this.
What do your temps look like?
Download a hardware monitor like HWiNFO https://www.hwinfo.com/
Open it up, start the log (spreadsheet with a little green plus sign in the bottom right).
Play (and stream) a game for a bit to give us a useful log (at least 3 to 5 minutes), exit the game and stop the log.
Share the log with us.
View the log using the GenericLogViewer addon https://www.hwinfo.com/add-ons/.
Edited by cr8tor
added more steps
Daily driver (looking to upgrade mobo and cpu spring of 2021)   --- The only time I sort by price from high to low is when I am shopping for CPU's and GPU's (looking for a cheap i7-7700k though)
Mobo: ASRock Z170 Extreme7+  CPU: i7-6700K @ 4.6MHz OC  Cooling: Corsair H115i Hydro  Memory: TridentZ 32GB @ 3600MHz  GPU: EVGA 2070 FTW3 ULTRA+ (OC'd 50/300)
PSU: Corsair HX850i   Storage: 980 Pro 1TB, 950 PRO 512Mb, (2)ADATA SU800 1TB  Keyboard: Logitech G910  Mouse: Logitech G502   Headset: Logitech G930 UPS: APC Pro 1500 S
Unraid box providing network routing, home automation services, and media services ( I love unraid!)
USB Key: SanDisk 16GB Ultra Fit  Mobo: Intel DX79SR Extreme+  CPU: i7-3820  Memory: 16Gb Kingston HyperX Predator  Storage: (cache)480gb Micron SSD (1)8TB HDD (1) 4TB HDD
GPU: MSI GTX 1650 4GT LP OC (passed through to Emby)  NIC: Intel I350-T4 4-port Gb (passed through to PFSense)  UPS: APC PRO 1000
Docker Containers: Emby and Home-Assistant-Core  Virtual machines: PFsense ( I love PFSense!)
Family machines
Mobo: Asus Prime H310M-E  CPU: Intel Core i3-9100F  Cooling: Deepcool Gammaxx 400  Memory: Teamgroup Elite Plus DDR4 16GB  Storage: Silicon Power 1TB NVMe M.2
GPU: Asus GTX 1660 Super 6GB or EVGA 1070 FTW 8GB  PSU: Thermaltake Smart 500W 80+  UPS: APC XS 1300
As well as a number of other machines, a ton of parts, miles of cables, and who knows what else!
Private message me for quicker assistance. I also build and ship custom machines at a really fair price.
Will do!
Looking at your specs and knowing that you are playing csgo while streaming it, i suspect you are doing more than your 108ti can handle.
But get us a log file like i mentioned above and that will help us help you.
Family machines
I will do it after I wake up its 4am here,
Thank you!
On 10/23/2020 at 3:27 PM, Jabilee said:
JABILEE.LOGIs this the log you mentioned?
No, HWiNFO should create a .csv file for a log file.
When you open HWiNFO you should see a button in the bottom right.
I included a screenshot with it in a red box.
Open it up and click that button (The green plus will switch to a red X to let you know its loggging. It will also ask you for a file name and where to save it. I usually just name it YR-MO-DA_log and point it to my desktop. It will automatically ad the .csv to the file.
Then go do your thing (stream a game) for 5 minutes or so, then come back, click that button again to stop logging.
then share the log file it created.
Family machines
Im not seeing anything obvious.
I suspect there is a background task that is kicking off and/or somehow causing this.
Is there any way you can create a log and be able to specify at what point in the log you see the frame drops?
Like run the log, and as soon as you see the stutter/drops stop the log and share it?
I ask, because nothing is jumping out at me, and it might help to know where in the log it happened so we can try to find a correlation.
Family machines
6 minutes ago, Jabilee said:
Here it is I experienced a fps drop from 400 to 150 last second
Do you mean your FPS dropped from 400fps to 150fps that last moment?
I ask because 400fps is really high, and i remember an issue in regards to really high framerates resulting in frame drops.
Fuzzy on the details right now, but ill find it and i wonder if that's what's going on.
Family machines
I usually max out my fps at 300, but same scenario happens my fps still drops
What monitor are you using?
And via HDMI or DisplayPort?
Family machines
Might be worth locking your FPS to 240 to see if that stops the frame drops.
Family machines
