So I've been having problems with my M6700, it's randomly turning all the screens a solid colour and freezing. from my googling it appears to be VRAM related and because the GPU in it (MXM RX 480) is definitely unofficial and has to have a modded vBIOS to run I'm not surprised it's that.
I downloaded GPUMemTest to see if that had any issues and sure enough when I run it there is a ton of artifacting all over the screens. I had already slowly lowered the GPU mem clock from 1250 MHz to 625MHz (as low as it lets me set it) hoping that that would help. However, this is where it gets interesting...
On a whim I decided to set the mem clock back to 1500Mhz (the clock the vBIOS sent with the card has) and sure enough all the artifacting immediately stops and I haven't had any solid colour crashes yet (though sometimes It happens every few minutes and sometimes it doesn't happen for a day or 2 so I'm not completely sure that solved it.
Anyone ever had problems from setting the memory clock too low? I'm just confused as to how that could possibly cause issues.
Edited by Mnky313
video didn't work
why no dark mode?
Current:
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz, Asus VG248QE 1080p@144hz
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 512GB HP EX NVMe SSD, 2TB Silicon Power NVMe SSD
Displays: Internal 1080p@300Hz
Custom Game Server:
CPUs: Ryzen 9 9900X
RAM: 128GB (4x32GB) DDR5 @ whatever it'll boot at xD (I think it's 3600MTs)
Storage: 2x 1TB WD Blue NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
There will be a voltage/frequency table in the card firmware. It's possible that under-clocking it outside of the expected values is leading to an incorrect VRAM voltage. Who modded the vBIOS? It's unusual to have to mod the GPU in this situation - usually you need to mod the laptop BIOS to allow unofficial GPU cards.
AFAIK these were pulled from the asrock deskminis or something similar, I don't think these were intended for laptops and definitely not my precision.
If I run the vBIOS that was sent to me on the card nothing shows up on the internal or external displays (and I had to reflash it with the modded one I found without any display, that was fun XD)
I have no idea the origin of the vBIOS  I have on the card, probably either a Chinese forum or Notebookreview, I included the vBIOSes in question in the attachments and an image of them in polaris BIOS editor.
All of them show VRAM voltage as 1000mV with clocks ranging from 1250-2000Mhz.
(I also uploaded all the other vBIOS I have though the only one working on the card in the laptop is 700.rom...)551292054_sentfromseller_rom.thumb.png.88a0be73b506ab56ab7dc8952ea6b0ce.png700_rom.thumb.png.13aba1559608239a5f033916cc510e80.png
700.rom Pulled from card.rom RX-480 from some forum.rom RX-480 MXM 4GB.rom Seller Sent Deskmini RX480 MXM.rom Sent from seller.rom
why no dark mode?
Current:
Custom Game Server:
CPUs: Ryzen 9 9900X
yeah, maybe. Idk why you responded with this twice.
The laptop BIOS allows other GPUs already, so idk what is wrong with the vBIOS that shipped with the card....
why no dark mode?
Current:
Custom Game Server:
CPUs: Ryzen 9 9900X
Random solid colour freezes are still happening but not as much it seems, I just had it happen after ~15 hours and decided to set the mem clock to 1625 (highest it lets me), if it still crashes i'll probably modify the vBIOS to let me set it to 1750 or 2000 MHz and see if that changes anything...
why no dark mode?
Current:
Custom Game Server:
CPUs: Ryzen 9 9900X
The forum keeps going unresponsive for me at certain times of day. No idea why, but it causes double-posting. I didn't submit it twice.
Are you sure there is no whitelist in the BIOS of the laptop? Many do, and one way around it is to alter the vBIOS vendor/device IDs. However, a better method is to add the IDs to the BIOS whitelist of the laptop, rather than alter the vBIOS. You can sometimes remove the whitelist feature altogether, but it's not as simple.
I thought there wasn't however I checked GPU-Z on the working vBIOS and it reports subvendor as Dell so maybe. Is there anyway to check/modify the subvendor ID of vBIOS.
I have a file with a ton of UEFI firmware Variables for the M6700. I can look for anything in there, short of that idk if I can modify the laptop BIOS.
why no dark mode?
Current:
Custom Game Server:
CPUs: Ryzen 9 9900X
Well, this is currently the end of this thread and my poor m6700...
not because the laptop is dead, its not (I hope).
However after flashing a modded vBIOS on the RX 480 (the working one with the subvendor changed) it no longer posts with the card in the laptop. (not what I was talking about where there is no display, completely no post... :(
Making it worse, the card isn't detected in the alienware (m17x R2 I believe) I tried it in so I have no way to reflash the vBIOS...
And just to top it off, the K3000M that was originally in this laptop is dead as well....
Here's a picture of the K3000M
20201023_191754.jpg?width=624&height=468
why no dark mode?
Current:
Custom Game Server:
CPUs: Ryzen 9 9900X
  • 4 weeks later...
Hi ! I just created in account in order to answer to you (I hope it isn't too late).
I could reflash a AMD 480 mxm card that was "dead" -> Like even booting in DOS using ATIflash could make it detected... (and the fans were spinning crazy).
I used a Linux (Ubuntu 20.04), I changed the boot option with "nomodeset" instead of "quiet splash" (Lot of information on the web on how to do it), and with https://github.com/patrickschur/amdvbflash I could flash a "working" bios. I put "" because right now I can only run OpenGL apps (I use Linux mostly).
I think that even with a live USB you could do that, or at least it worth the try ;)
And also you can try to flash directly the bios chip with an eeprom reader like the CH341A, I've saved a lot of motherboard with this little and cheap machine !
Anyway i'll try to flash your bioses in my card, and I'll see what happen !
Cheers and sorry for any English misspelling, weird language etc : English isn't my native language.
Yeah, I've also seen it's probably possible to reflash the vBIOS using a USB programmer as for using a live USB for reflashing it I don't think that's possible. I've reflashed the card without being able to see the screen by just using sound and cmd and a lot of luck XD but after I flashed the vBIOS the laptop won't even post with the card in it, idk what was so bad about that vBIOS.
I might get a USB programmer if I feel like reviving the laptop but for now I turned the display into a portable monitor and I need a new chassis/frame because the CPU heatsink mounting holes are completely destroyed so for now i'm just shelving it.
Thanks for the help and ideas though!
why no dark mode?
Current:
Custom Game Server:
CPUs: Ryzen 9 9900X
