Hi!
I recently switched from an old blue yeti because it was having weird gain issues on my computer. It started with that one of my two front usb ports made the gain for my yeti really loud but the other one didn't. Untill it also began having the same issue. So i bought a new mic, an xlr mic. Now after like one week of using it, i have ran into the same issue that one of my usb port on the back of my computer makes the gain really loud. I have no idea what can cause this, any clues?
https://linustechtips.com/topic/1260524-weird-usb-issue/
12 minutes ago, TrYeX said:
Hi!
Låter konstigt. Vad har du för moderkort?
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
https://linustechtips.com/topic/1260524-weird-usb-issue/#findComment-14140812
Just now, TrYeX said:
Msi z270i gaming pro carbon ac
Förklara hur det låter eller spela in och skicka en länk.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1260524-weird-usb-issue/#findComment-14140905
5 minutes ago, TrYeX said:
Och det låter normalt när jag har på en annan usb port.
Så volymen ökar automatiskt?
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1260524-weird-usb-issue/#findComment-14140942
Ja, det är som att porten ger högre gain. Typ att den skickar ännu mer el?
Varför sänker du inte volymen i windows inställningarna? 1114550193_Skrmklipp.thumb.PNG.8d1b5e7ed8e0d9a3f201266c3f47bcb5.PNG
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1260524-weird-usb-issue/#findComment-14140958
När jag drar mikrofon slidern till 0 så ändras inte ljudet från mikrofonen för mig. Dock ifall jag drar gainen på micen till 0 på mitt ljudinterface så får jag normal gain men mycket noise.
https://linustechtips.com/topic/1260524-weird-usb-issue/#findComment-14140968
Det var inget, ändringarna kom inte fram i audacity men i dc kommer de fram
Adda mig på discord om du vill. Så kanske vi kan lösa det. Om du inte har fixat det dock.
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1260524-weird-usb-issue/#findComment-14140972
Tror jag fick en rätt så okej lösning på det. Vi får se ifall det håller i långänden. Tack som fan för hjälpen!
Inga problem!! :)
AKG P420 Mic
Other peripherals
https://linustechtips.com/topic/1260524-weird-usb-issue/#findComment-14140982
I'm not going to tell on you guys or anything but one of the rules is that this is an English only forum so just be careful 😆😆
holy crap, emojis post in italic..
 Hahahaha
Italic emojis are crazy man
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
https://linustechtips.com/topic/1260524-weird-usb-issue/#findComment-14141416
