i dont see rgb. i see hours in the garage with a heat gun and various tools for bending.
still a pretty picture though.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1260348-first-hardline-pc/#findComment-14139375
42 minutes ago, goovy20 said:
Hey, this is my first full hardline build. Does anybody have some good tricks for bleeding the loop ? TYIA
Flip it upside down and rock and forth and side to side. I’d leave it upside down for at least a few days. Put some books under it to elevate it off the floor so you let the fans exhaust.
https://linustechtips.com/topic/1260348-first-hardline-pc/#findComment-14139381
I had it like 24 hours running the loop. That's not long enough probably ?
https://linustechtips.com/topic/1260348-first-hardline-pc/#findComment-14139387
Upside down for 24 hours?
My loops usually take a few days to get all the large bubbles out, and 1-2 weeks to get all the micro bubbles out.
https://linustechtips.com/topic/1260348-first-hardline-pc/#findComment-14139394
24 hours upside down. The res. is vertical then... and top cap off
Res should still be horizontal if you flip it upside down.... lol. It’ll just be at the top of the loop and will gather all the air bubbles in it.
https://linustechtips.com/topic/1260348-first-hardline-pc/#findComment-14139410
Do you think there is a possibility that the loop can suck air, with no leak of liquid ? Or i'm thinking to mechanical ?
https://linustechtips.com/topic/1260348-first-hardline-pc/#findComment-14139429
Very much doubt it.
https://linustechtips.com/topic/1260348-first-hardline-pc/#findComment-14139550
This is impressive but when I hear about days of bleeding etc. I am glad I am 100% aircooled!
Intel i9-13900K - Gigabyte Aorus Z790 Elite DDR4 - Corsair Vengeance LPX 128GB DDR4 3200 C16 - Gigabyte Aorus Master RTX 4090 24GB - Corsair 4000D Airflow - 2x Samsung 980 Pro 1TB  - Corsair AX1600i 80 PLUS Titanium 1600W - Aorus FI27Q - Noctua NH-D15 running 3 fans (CPU) - 6 x NF-A12x25 (3 intake, 3 exhaust) - Aorus K1 - Aorus M5 - Aorus AMP500 - Aorus H5 - Corsair TC70 - Win 11 Pro
https://linustechtips.com/topic/1260348-first-hardline-pc/#findComment-14141419
