Budget: ~$1300 USD
Country: USA
Games, programs or workloads that it will be used for: A bit above casual gaming
I only need a monitor and keyboard.
This is my first PC.
I know Zen 3 and new entry level graphics cards are coming out soon, so the price might go down just a bit.
I'm not too sure about the monitor and I know the keyboard is over kill, I might change it.
I would love some suggestions if I should change anything.
Thanks in advance.
https://linustechtips.com/topic/1259960-first-build/
Thanks in advance.
What type of keyboard switch do you like, Razer has all their keyboards overpriced so I can help you on that front.
And yes wait for the 5600 and the 3060.
F@H [] Autobiography []
Main Desktop and Folding Rig :
Cpu : I5-9400f
Gpu : GTX 1070 Founder's Edition
Psu : Seasonic G-650
Ram : G.Skill Aegis 4x8gb DDR4 2666MHz (14-15-15-34)
External Storage : 8tb Western Digital Elements Usb 3.0 Hard Drive
Storage : Samsung 970 Evo 500GB
Motherboard : ASUS B365 Pro-4 m
Gaming Laptop :
Cpu : I7-8750H 2.2ghz
Gpu : GTX 1070 Max Q
Psu : laptop b r i c k
Ram : 16gb 2666Mhz
Storage : 512Gb SATA SSD
Motherboard : it's a laptop.....
old boomer (currently non-functional)
Cpu : I5-6400 2.7ghz (doesn't have a heatsink)
Gpu : Asus RX580 8gb (might sell)
Psu : EVGA 500 watt 80 plus
Ram : 16gb DDR3 1400mhz
Storage : 1tb Toshiba HDD (currently in main pc)
Motherboard : Generic ASUS pre-built motherboard
https://linustechtips.com/topic/1259960-first-build/#findComment-14135924
1 hour ago, baconbreathmints said:
I think my favorite out of the razor switches would be the orange.
So tactile, but super loud I think.
EDIT: I forgot to say, I don't care about looks at all. I am not going to be looking at it.
Then why do rgb?  I’m also not so sure the monitor and gpu make such a great pairing.
https://linustechtips.com/topic/1259960-first-build/#findComment-14136086
